Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
(A1 blocks and A2 blocks) modify the block color
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: (A1 blocks and A2 blocks) modify the block color (Read 1095 times)
well20152016
Newt
on:
January 15, 2017, 09:10:22 AM »
Logged
well20152016
Newt
Re: (A1 blocks and A2 blocks) modify the block color
Reply #1 on:
January 16, 2017, 07:54:37 PM »
Code - Auto/Visual Lisp:
[Select]
defun
c:tt
setq
En1
nentsel
\n
Pick an entity or subEntity: "
En2
nentsel
\n
Pick other entity or subEntity: "
Es1
entget
car
En1
Es2
entget
car
En2
if
cdr
assoc
62
Es1
setq
Es1
subst
cons
62
2
assoc
62
Es1
Es1
setq
Es1
append
Es1
list
cons
62
2
if
cdr
assoc
62
Es2
setq
Es2
subst
cons
62
2
assoc
62
Es2
Es2
setq
Es2
append
Es2
list
cons
62
2
entmod
Es1
entmod
Es2
LM:Regen
princ
defun
LM:Regen
vl-load-com
setq
thisdrawing
vla-get-activedocument
vlax-get-acad-object
vla-Regen
thisdrawing acAllViewports
princ
There is no way? (ssget method)
Last Edit: January 16, 2017, 08:10:18 PM by well20152016
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
