Author Topic: External Data Storage with XML and VLISP  (Read 33865 times)
« Reply #30 on: January 07, 2004, 05:33:35 PM »
I need to do some more reading on this subject!
I dont see the purpose of calling any sort of dll when all it really (?) is, is a text file.  ...im i wrong?
SMadsen
« Reply #31 on: January 07, 2004, 05:51:10 PM »
XML is more of a database than text. Nice things can be done with XML and I think MS XML DOM is well worth the effort to get to know.
AutoCAD is making more use of XML for each release. E.g. the toolbar palettes are written in XML and the main exchange format will soon be XML based.
« Reply #32 on: January 07, 2004, 05:55:44 PM »
Oh i get cha. Im gonna try to do some reading tonight. Then im gonna work on some flowcharts for some quick tools i could create.
daron
« Reply #33 on: January 07, 2004, 06:25:21 PM »
Also, if I remember correctly, that "swanky" layer dialog that I put up on the ADT forum was written with xml.
Columbia
Re: External Data Storage with XML and VLISP
« Reply #34 on: May 14, 2008, 10:15:31 AM »
It's been 4+ years since I posted the .vlx for the xml-api.  Anybody want the source code?
daron
« Reply #35 on: May 14, 2008, 10:24:47 AM »
Yes, please.
deegeecees
« Reply #36 on: May 14, 2008, 10:30:46 AM »
psuchewinner
« Reply #37 on: May 14, 2008, 10:36:02 AM »
Columbia.  I just sent you a message.
I am having trouble getting it to work.  Would you, could you, Help me/us?
Columbia
« Reply #38 on: May 14, 2008, 11:42:40 AM »
Okay, you guys asked for it...
;;; api-xml.lsp
;;; Prepared by: J. Szewczak
;;; Date: 4 January 2004
;;; Purpose: To provide an API for interfacing with XML files.
;;; Copyright (c) 2004 - AMSEC LLC - All rights reserved
;;; Version 2004.01.04
;;; MODULE: api-error
;;; DESCRIPTION: wraps a function to trap Active-X errors - if error is found
;;; DESCRIPTION: function returns nil.
;;; ARGS: function to check, list of arguments, boolean (return error message?) T or nil
;;; EXAMPLE: (api-error '/ (list 50 0) T) displays "VLISP Error: divide by zero" & returns 'nil'
(defun api-error (func lst bool / trap)
    ( (vl-catch-all-error-p
        (setq trap (vl-catch-all-apply func lst))
      (if bool (princ (strcat "\nVLISP XML Error: " (vl-catch-all-error-message trap))))
      (setq trap nil)
  trap
;;; MODULE: XML-Get-Document
;;; DESCRIPTION: queries an XML file for the DOM Active-X object
;;; ARGS: XML file (string); a variable to store the DOM object
;;; EXAMPLE:(XML-Get-Document projfile 'XMLDoc) returns vla-object
(defun XML-Get-Document (file XMLDoc)
  (if (findfile file)
      (set XMLDoc (vlax-create-object "MSXML2.DOMDocument.3.0")) ;;create XML-DOM pipeline
      (vlax-put-property (eval XMLDoc) "async" :vlax-false)
        ( (api-error 'vlax-invoke-method (list (eval XMLDoc) "Load" file) T) ;; Load Project File into XML-DOM pipeline
          (eval XMLDoc)
    (alert "\nXML Document could not be found.")
;;; MODULE: XML-Get-XMLObject
;;; DESCRIPTION: this gets the top-level parent node object in a given XML Document
;;; ARGS: filename (string)
;;; EXAMPLE: (XML-Get-XMLObject filename) returns VLA-OBJECT
(defun XML-Get-XMLObject (file / docObj xmlTop xmlVer object)
  (if (findfile file)
      (setq docObj (XML-Get-Document file 'docObj)
            xmlTop (vlax-get-property docObj "childNodes") ;; Get the Top Level of the XML
            xmlVer (vlax-invoke-method xmlTop "nextNode")  ;; Gets the XML version element
            object (vlax-invoke-method xmlTop "nextNode")  ;; Gets the Parent element
  object
;;; MODULE: XML-Get-ElementKey
;;; DESCRIPTION: returns the requested tags text.
;;; ARGS: Parent - the parent collection object, tag name - must be unique tag name
;;; EXAMPLE: (XML-Get-ElementKey laydef "Name") returns "ANNOTATION"
(defun XML-Get-ElementKey (parent tag / el desc)
  (if (vlax-method-applicable-p parent 'getElementsByTagName)
      (setq el (vlax-invoke-method parent 'getElementsByTagName tag))
      (if (> (vlax-get-property el 'Length) 0)
        (setq desc (vlax-get-property (vlax-invoke-method el 'nextNode) 'text))
      (vlax-invoke-method el 'reset)
    (princ "\nXML Object could not be searched.")
  (if desc desc nil)
;;; MODULE: XML-Get-ElementKey-Object
;;; DESCRIPTION: returns the requested tags object.
;;; EXAMPLE: (XML-Get-ElementKey-Object laydef "Name") returns VLA-OBJECT
(defun XML-Get-ElementKey-Object (parent tag / el desc)
        (setq desc (vlax-invoke-method el 'nextNode))
  (if desc desc nil)
;;; MODULE: XML-Get-Parent
;;; DESCRIPTION: Gets a top level object from the XML object with the given name
;;; ARGS: a valid XML object, the name of the parent level
;;; EXAMPLE: (XML-Get-Parent oXML "Leaders") returns VLA-OBJECT
(defun XML-Get-Parent (oXML name)
  (vlax-invoke-method
    (vlax-invoke-method oXML 'GetElementsByTagName name)
   'peekNode
;;; MODULE: XML-Get-Children
;;; DESCRIPTION: gets the child object from a parent level
;;; ARGS: XML object, Parent name
;;; EXAMPLE: none
(defun XML-Get-Children (oXML parentName / return)
    ( (/= parentName nil)
      (if (vlax-invoke-method (XML-Get-Parent oXML parentName) 'hasChildNodes)
        (setq return (vlax-get-property (XML-Get-Parent oXML parentName) 'childNodes))
    ( T (if (vlax-invoke-method oXML 'hasChildNodes) (setq return (vlax-get-property oXML 'childNodes))))
  return
;;; MODULE: XML-Get-ChildList
;;; DESCRIPTION: returns a list of all child objects under a parent XML Object
;;; EXAMPLE: (XML-Get-ChildList objXML) returns a list of VLA-Objects
(defun XML-Get-ChildList (oXML / collection child lst)
    ( (vlax-invoke-method oXML 'hasChildNodes)
      (setq collection (XML-Get-Children oXML nil))
      (while (setq child (vlax-invoke-method collection 'nextNode))
        (setq lst (if lst (cons child lst) (list child)))
      (reverse lst)
    (princ "\nObject has no children")
;;; DESCRIPTION: gets a specific child name under the parent level with given name
;;; ARGS: XML object, parent level, child name
;;; EXAMPLE: (setq oPointers (XML-Get-Child oXML "Leaders" "Pointers")) returns VLA-Object
;;; EXAMPLE: (XML-Get-Child oPointers nil "ArrowSize") used you only want to go one deep...
(defun XML-Get-Child (oXML parentName childName / child target)
    ( (/= parentName nil) (setq child (XML-get-Children oXML parentName)))
    ( T (setq child (vlax-get-property oXML 'childNodes)))
  (setq target (api-error 'vlax-invoke-method (list child 'nextNode) T))
  (while
    (and
      target
      (/= (vlax-get-property target 'tagName) childName)
  target
;;; MODULE: XML-Get-Child-ByAttribute
;;; DESCRIPTION: gets a specific child name under the parent level with given attribute and attribute value
;;; ARGS: XML object, parent level, attribute to search by, attribute value to match
;;; EXAMPLE: (XML-Get-Child-ByAttribute oLayers "LayerDefinitions" "Name" "ANNOTATION") returns VLA-OBJECT
;;; EXAMPLE: (XML-Get-Child-ByAttribute oLayerDefs nil "Name" "ANNOTATION") used when you only want to go one deep...
(defun XML-Get-Child-ByAttribute (oXML parentName attrib attribValue / parent rtn)
  (if parentName
    (setq parent (XML-Get-Child oXML nil parentName))
    (setq parent oXML)
  (foreach itm (XML-Get-ChildList parent)
    (if (= (XML-Get-Attribute itm attrib "") attribValue)
      (setq rtn itm)
  rtn
;;; MODULE: XML-Get-Child-Value
;;; DESCRIPTION: Retrieves the value from the 'Text property of a child element
;;; ARGS: XML object, parent Name, Child Name
;;; EXAMPLE: (XML-Get-Child-Value oXML "TaskInfo" "FSCM") returns "4T323"
(defun XML-Get-Child-Value (oXML parentName childName)
  (if (XML-Get-Child oXML parentName childName)
    (vlax-get-property (XML-Get-Child oXML parentName childName) 'text)
    nil
;;; MODULE: XML-Put-Child
;;; DESCRIPTION: updates the text in a given child node
;;; ARGS: XML object, parent node name, child node to change, value to change to
;;; EXAMPLE: (XML-Put-Child oXML "DrawingSetup" "DrawingMode" "MicroScale")
(defun XML-Put-Child (oXML parentName childName valu / child return)
    (and
      valu
      (setq valu (vl-princ-to-string valu))
      (setq child (XML-Get-Child oXML parentName childName))
    (api-error 'vlax-put-property (list child 'text valu) T)
;;; MODULE: XML-Remove-Child
;;; DESCRIPTION: removes the specified child object node
;;; ARGS: XML node object
;;; EXAMPLE: (XML-Remove-Child oXML)
(defun XML-Remove-Child (rmvChild / parent)
  (setq parent (vlax-get-property rmvChild 'parentNode))
  (api-error 'vlax-invoke-method (list parent 'removeChild rmvChild) T)
;;; MODULE: XML-Add-Child
;;; DESCRIPTION: adds a Child element to the given parent object
;;; ARGS: Parent Level VLA-Object, name of new child
;;; EXAMPLE: (XML-Add-Child oXML "LayerKey") returns the newly created child node object
(defun XML-Add-Child (parent name / xmlDoc newElement return)
  (setq xmlDoc (vlax-get-property parent 'ownerDocument))
  (if (not parent) (setq parent xmlDoc))
  (if (setq newElement (api-error 'vlax-invoke-method (list xmlDoc 'createElement name) T))
    (setq return (api-error 'vlax-invoke-method (list parent 'appendChild newElement) T))
  return
;;; MODULE: XML-Get-Attribute
;;; DESCRIPTION: returns an XML object's named attribute value
;;; ARGS: XML object, attribute name (string), a default value to return if there is no value found in the XML object
;;; EXAMPLE: (XML-Get-Attribute oXML "Name" "Default") might return "ANNOTATION"
(defun XML-Get-Attribute (oXML name default / att return)
  (if (setq att (api-error 'vlax-invoke-method (list oXML 'getAttributeNode name) T))
    (if att
      ;; due to the fact that the Text property strips trailing and leading white characters
      ;; when using the 'get' method.  the Value property has been used instead.
      (vlax-variant-value (vlax-get-Property att "Value"))
      default
;;; MODULE: XML-Get-Attribute-List
;;; DESCRIPTION: returns a list of strings corresponding to the names of the XML object's attributes
;;; EXAMPLE: (XML-Get-Attribute-List oXML) might return ("Name" "Color" "LineType" "LineWeight" "Plottable" "Comment")
(defun XML-Get-Attribute-List (oXML / lst attCollection count)
  (if (setq attCollection (vlax-get-property oXML 'attributes))
      (setq count 0)
      (while (< count (vlax-get-property attCollection 'length))
        (setq lst (append lst (list (vlax-get-property (vlax-get-property attCollection 'item count) 'Name)))
              count (1+ count)
  lst
;;; MODULE: XML-Put-Attribute
;;; DESCRIPTION: function to put an XML attribute value -- will add the attribute if not already there
;;; ARGS: XML object, attribute name (string), a value to change the attribute to
;;; EXAMPLE: (XML-Put-Attribute oXML "Name" "Default") might return vla-object
(defun XML-Put-Attribute (oXML name valu / att return)
    ( valu (setq valu (vl-princ-to-string valu)))
    ( (not valu) (setq valu ""))
  (if (not (XML-Get-Attribute oXML name nil))
    (XML-Add-Attribute oXML name "")
  (api-error 'vlax-invoke-method (list oXML 'setAttribute name valu) T)
;;; MODULE: XML-Add-Attribute
;;; DESCRIPTION: adds an attribute to the Parent Object with given name, and the optional value
;;; ARGS: Parent Level VLA-Object, name of new attribute, value (optional)
;;; EXAMPLE: (XML-Add-Attribute oXML "Name" "Default") returns the newly created attribute XML object.
(defun XML-Add-Attribute (parent name valu / xmlDoc newAttribute newAtt)
  (if (setq newAttribute (api-error 'vlax-invoke-method (list xmlDoc 'createAttribute name) T))
      (setq attNodeMap (vlax-get-property parent 'attributes)
            newAtt (api-error 'vlax-invoke-method (list attNodeMap 'setNamedItem newAttribute) T)
      (if valu (vlax-put-property newAtt 'Text valu))
  newAtt
;;; MODULE: XML-Get-Value
;;; DESCRIPTION: Retrieves the value from the 'Text property of the supplied XML Element object
;;; EXAMPLE: (XML-Get-Value oXML) returns "4T323"
(defun XML-Get-Value (oXML)
  (api-error 'vlax-get-property (list oXML 'text) T)
;;; MODULE: XML-Put-Value
;;; DESCRIPTION: Puts a text value into the 'Text property of the supplied XML Element object
;;; ARGS: XML object, text string
;;; EXAMPLE: (XML-Put-Value oXML "4T323") returns T if successful nil if not.
(defun XML-Put-Value (oXML str)
  (api-error 'vlax-put-property (list oXML 'text str) T)
  (if (= (XML-Get-Value oXML) str)
    T
    nil
;;; MODULE: XML-SaveAs
;;; DESCRIPTION: Writes the parsed XML object out to the given file
;;; ARGS: XML document object or XML element object, fully qualified filename to save to
;;; EXAMPLE: (XML-SaveAs oXML "C:\\projects\\npy structure.swp")
(defun XML-SaveAs (oXML file)
    ( (= (vlax-get-property oXML 'nodeTypeString) "element")
      (api-error 'vlax-invoke-method (list (vlax-get-property oXML 'ownerDocument) 'save file) T)
    ( T (api-error 'vlax-invoke-method (list oXML 'save file) T))
;;; DESCRIPTION: Writes the parsed XML object out to its parent file
;;; EXAMPLE: (XML-Save oXML)
(defun XML-Save (oXML / doc file)
      (setq doc (vlax-get-property oXML 'ownerDocument))
    ( T (setq doc oXML))
  (setq file (vl-string-subst "\\" "/" (vl-string-left-trim "file:///" (vlax-get-property doc 'url))))
  (api-error 'vlax-invoke-method (list doc 'save file) T)
By the way, this uses MSXML2.DOMDocument.3.0 for its library, but that can & should be updated to MSXML2.DOMDocument.6.0.
Happy coding!!!
daron
« Reply #39 on: May 14, 2008, 12:13:39 PM »
Thank you.
GDF
« Reply #40 on: May 14, 2008, 02:27:05 PM »
Happy coding!!!
Ok, thanks for sharing it. Now can you give some examples, for us simple minded folks.
Gary
Columbia
« Reply #41 on: May 15, 2008, 10:51:31 AM »
Contents of an example XML File (named C:\dwgset.xml) as follows:
<?xml version="1.0"?>
<Settings>
  <Layers>
    <Layer Name="Walls" Color="" LineType="continuous"/>
    <Layer Name="Furniture" Color="3" LineType="HIDDEN"/>
  </Layers>
  <DrawingVars>
    <RegenAuto>1</RegenAuto>
    <EdgeMode>0</EdgeMode>
    <Osmode>383</Osmode>
  </DrawingVars>
</Settings>
Now here are some statements that use the XML-API to query the above XML file.
;; Load the VisualLISP stuff
;; Store an Active-X object to the main node ("Settings") of the XML data file.
(setq oSettings (XML-Get-XMLObject "C:\\dwgset.xml"))
;; Store an Active-X object to the "DrawingVars" node of the XML file.
(setq oDwgVars (XML-Get-Child oSettings nil "DrawingVars"))
;; The following two lines return the exact same thing.
;; An string object representing the value stored in the RegenAuto child node of the DrawingVars node.
(setq sRegenValue (XML-Get-Child-Value oDwgVars nil "RegenAuto"))
(setq sRegenValue (XML-Get-Child-Value oSettings "DrawingVars" "RegenAuto"))
;; Return the value that is stored inside a "Color" attribute from the child node of Layers whose "Name" attribute = "Walls"
(setq color
  (read
    (XML-Get-Attribute
      (XML-Get-Child-ByAttribute oSettings "Layers" "Name" "Walls") "Color" "-1")
;; if the value for 'color' that we got above is less than the zero (our supplied default argument was -1).
;; then we'll set that attribute to 2.
(if (< color 0)
    (XML-Put-Attribute (XML-Get-Child-ByAttribute oSettings "Layers" "Name" "Walls") "Color" 2)
    ;; After changing the Active-X object that is resident in memory,
    ;; we have to save all of our changes back to the XML file.
    (XML-Save oSettings)
;; release the objects
(vlax-release-object oSettings)
(vlax-release-object oDwgVars)
And now after the XML-Save function call the XML file should look like this:
<Settings>
  <Layers>
    <Layer Name="Walls" Color="2" LineType="continuous"/>
  </Layers>
  <DrawingVars>
  </DrawingVars>
</Settings>
I hope that gets y'all on your way...
psuchewinner
« Reply #42 on: May 15, 2008, 11:53:42 AM »
There must be a setting that is wrong with my computer or something that is not loaded because if I copy and paste this, it still does not work.
Do I need to have something load?  The VLX is loaded.
Sorry for not getting this stuff.  I am starting to get frustrated.
This is what I am getting:
_$ (setq oSettings (XML-Get-XMLObject "C:\\dwgset.xml"))
#<VLA-OBJECT IXMLDOMProcessingInstruction 023e8ee8>
_$ (setq oDwgVars (XML-Get-Child oSettings nil "DrawingVars"))
nil
; error: bad argument type: VLA-OBJECT nil
_$ (setq sRegenValue (XML-Get-Child-Value oSettings "DrawingVars" "RegenAuto"))
; error: ActiveX Server returned the error: unknown name: GETELEMENTSBYTAGNAME
Columbia,
As you stated in my other post, I should not get a nil for oDwgVars.....seem like it is crashing there.
Columbia
« Reply #43 on: May 15, 2008, 01:01:48 PM »
Do this in the VLIDE...
(setq xmldoc (xml-get-document "c:\\dwgset.xml" 'xmlDoc))
(vlax-dump-object (vlax-get xmldoc 'ParseError))
If there is an error with the file it should show up in the dump listing.
psuchewinner
« Reply #44 on: May 15, 2008, 01:04:27 PM »
#<VLA-OBJECT IXMLDOMDocument2 023ef7a8>
; IXMLDOMParseError: structure for reporting parser errors
; Property values:
;   errorCode (RO) = 0
;   filepos (RO) = 0
;   line (RO) = 0
;   linepos (RO) = 0
;   reason (RO) = ""
;   srcText (RO) = ""
;   url (RO) = ""
T
All is well with the file????
