Author Topic: Command line will display a lot of ( Lisp Expression).............  (Read 1840 times)
Rosamund
  • Mosquito
Hi guys
Frist .Best wishes ! Wish you have a merry Christmas holiday.
I have a question too.
Sometimes , Use a lisp to do something. when finish ,I want undo , use Ctrl+ Z
I found a strange phenomenon in  Command Line. See attachment  image.
When use "Ctrl+z" undo ,  Command line will display a lot of ( Lisp Expression).............  Why ?
Some people answer me because in Lisp file No use (command "_.undo" "be") and (command "_.undo" "e").
I see that ,In Lisp file have already used  (LM:startundo (LM:acdoc))  and  (LM:endundo (LM:acdoc)).
How to make it not display ? Thanks a lot .
roy_043
  • BricsCAD 18
Re: Command line will display a lot of ( Lisp Expression).............
« Reply #1 on: December 28, 2016, 08:23:33 AM »
It would help if you post the Lisp code.
