Just as aside, I figured I could use the -mtext command and do the same thing. I can configure the dynamic columns and column height OK with the -mtext command, but then I run into some kind of character limit with -mtext. It must be somewhere around 1,200 or 1,550 characters, depending on if you count spaces that I can paste from the clipboard.
