Author Topic: Keys Attributes Values  (Read 6631 times)
QuestionEverything
« on: November 30, 2016, 11:34:10 AM »
My question might sound weird, but:
Is there a reason not to assign a Key or Attribute or a Value onto a tile?
For example the : text tile, doesn't always need to have a key or a value if its used as a "label" for something next to it.
Can you share some info from your experience?
Re: Keys Attributes Values
« Reply #1 on: November 30, 2016, 01:44:50 PM »
A tile 'key' attribute is only required if the tile needs to be manipulated at runtime by the program - the key provides a way to uniquely reference the tile.
Provided a tile has either the is_default or is_cancel attribute, you can load & display a dialog with no tile keys:
  1. (defun c:test ( / *error* dch dcl des )
  2.     (and (setq *error*
  3.             '(   ( m )
  4.                  (if (< 0 dch) (unload_dialog dch))
  5.                  (if (= 'file (type des)) (close des))
  6.                  (if (and (= 'str (type dcl)) (findfile dcl)) (vl-file-delete dcl))
  7.              )
  8.              dcl (vl-filename-mktemp nil nil ".dcl")
  9.              des (open dcl "w")
  10.          )
  11.          (princ "d:dialog{spacer;:edit_box{edit_width=20;}:button{label=\"Exit\";is_cancel=true;}spacer;}" des)
  12.          (not (setq des (close des)))
  13.          (< 0 (setq dch (load_dialog dcl)))
  14.          (new_dialog "d" dch)
  15.          (start_dialog)
  16.     )
  17.     (*error* nil) (princ)
  18. )
QuestionEverything
« Reply #2 on: November 30, 2016, 02:25:51 PM »
  3.             '(   ( m )
  7.              )
  10.          )
  15.          (start_dialog)
  16.     )
  18. )
After reading your comment I'm left with the impression that the whole thing works like an association list:
'((<Key1> <Label1> <Value1> <Expr1>)(<Key2> <Label2> <Value2> <Expr2>) .... (<KeyN> <LabelN> <ValueN> <ExprN>))Where each item represents a tile and depending on your intentions, you might want to(or not) assign something to it.
And ofcourse accesing the tile through its <Key> (optional), similarly to the Tile- and Attribute-Handling Functions aka *_tile functions, like you said "if the tile needs to be manipulated".
Tho replicating the ok and cancel buttons by using is_default or is_cancel attributes, I wanted to ask how to access the help, info and errtile tiles, when using these built-in functions:
ok_cancel_help_info;
ok_cancel_help_errtile;
Thank you!
roy_043
  • BricsCAD 18
« Reply #3 on: November 30, 2016, 02:41:23 PM »
Provided a tile has either the is_default or is_cancel attribute...
An action attribute defined in the DCL that includes (done_dialog) also works.
« Reply #4 on: November 30, 2016, 03:06:38 PM »
I don't see the link to an association list, but note that you can assign labels & values to tiles without keys.
The "ok" tile has key "accept" and the errtile has key "error"; the other tiles have keys equal to their tile names.
See:
http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-0376DCD0-ACF6-4269-982E-E396E81C4D93
http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-BA3EADFA-E2D7-4D85-9282-3CBB0D83499E
http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-DF8DA7C3-7F7E-471C-A6B9-1A5D986CD6E9
http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-01A41A6D-5972-4A33-99B8-BA7B7A379527
http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-9FB4A683-23CA-4B6C-A5EF-5E43AE7C8D4B
Note that this is not valid in AutoCAD; also, the action attribute value will only be evaluated for tiles with keys.
QuestionEverything
« Reply #5 on: November 30, 2016, 04:12:00 PM »
Sorry I was trying to explain this to myself in lisp words (the tile and their attributes thing), since the DCL LSP connection is inevitable.
See:
Now I'll remember that the following names for keys:
"accept" "cancel" "help" "info" "error"Are "protected" (like saying protected symbols) so will try to avoid these names when manually asignning a key attribute.
Thanks alot, you are very helpful! :)
« Reply #6 on: November 30, 2016, 04:30:22 PM »
On the contrary - since these tiles have predefined action statements, you can exploit this to avoid the need to define action_tile expressions for your tiles:
  3.             '(   ( m )
  7.              )
  10.          )
  11.          (write-line
  12.              (strcat
  13.                  "dia : dialog"
  14.                  "{"
  15.                  "    label = \"Example\";"
  16.                  "      children_alignment = centered;"
  17.                  "    spacer;"
  18.                  "    : edit_box { edit_width=40; }"
  19.                  "    spacer;"
  20.                  "    : button"
  21.                  "    {"
  22.                  "        label = \" Custom OK Button \";"
  23.                  "        fixed_width = true;"
  24.                  "        height = 3.0;"
  25.                  "        key = \"accept\";"
  26.                  "        is_default = true;"
  27.                  "    }"
  28.                  "    spacer;"
  29.                  "}"
  30.                  )
  31.              des
  32.          )
  33.          (not (setq des (close des)))
  34.          (< 0 (setq dch (load_dialog dcl)))
  35.          (new_dialog "dia" dch)
  36.          (start_dialog)
  37.     )
  38.     (*error* nil) (princ)
  39. )
You're welcome!
Grrr1337
« Reply #7 on: November 30, 2016, 06:42:06 PM »
  1.         "dia : dialog"
  2.         "{"
  3.         "    label = \"Example\";"
  4.         "       children_alignment = centered;"
  5.         "    spacer;"
  6.         "    : edit_box { edit_width=40; }"
  7.         "    spacer;"
  8.         "    : button"
  9.         "    {"
  10.         "        label = \" Custom OK Button \";"
  11.         "        fixed_width = true;"
  12.         "        height = 3.0;"
  13.         "        key = \"accept\";"
  14.         "        is_default = true;"
  15.         "    }"
  16.         "    spacer;"
  17.         "}"
  18. )
  19.
Hi Lee,
I love the DCL-string formatting you did, do you use some snippet for this?
Because I think about writing some (in case you did this by hand).
BTW, Nice thread! (sorry for the offtopic)
(apply ''((a b c)(a b c))
QuestionEverything
« Reply #8 on: December 01, 2016, 05:18:37 AM »
Now I know that:
  1. is_default; equals to (action_tile "accept" "(done_dialog 1)")
  2. is_cancel; equals to (action_tile "cancel" "(done_dialog 0)")
Just like roy_043 mentioned.
And if I would use one of these:
ok_cancel_help;
I will need to define action_tile expressions for these keys: "help" "info" "error".
So there are various ways to handle the ok and cancel buttons.
Similairly for custom cancel button (from your example):
  1. "    : button"
  2. "    {"
  3. "        label = \" Custom Cancel Button \";"
  4. "        fixed_width = true;"
  5. "        height = 3.0;"
  6. "        key = \"cancel\";"
  7. "        is_cancel = true;"
  8. "    }"
  9.
roy_043
  • BricsCAD 18
« Reply #9 on: December 01, 2016, 09:04:26 AM »
Are you saying that (done_dialog) is not allowed in an action attribute? That seems strange.
Grrr1337
« Reply #10 on: December 01, 2016, 09:15:53 AM »
Roy, he was 'talking' about tiles with no keys (then you cannot asign <expr> using action_tile).
Since op stated:
« Reply #11 on: December 01, 2016, 03:13:21 PM »
I write DCL code in the Visual LISP IDE, and use the same to convert to string format simply using the various find/replace/prefix/append options offered by the IDE.
You may get some ideas from this old program: Format DCL.
Now I know that:
Not quite: this equivalence is only applicable to the is_cancel attribute; the is_default attribute will only set the tile as the default and will not assign an action - if in doubt, simply include the tile keys.  :-)
No, (done_dialog) is a perfectly valid action attribute value in AutoCAD, however, I was asserting that the action expression will only be evaluated for tiles with keys (per Grrr1337 above). Also, that this action expression alone is not sufficient for a valid DCL GUI: the tile must also have either an is_cancel or is_default attribute (else AutoCAD will complain that the GUI has no OK or Cancel button).
roy_043
  • BricsCAD 18
« Reply #12 on: December 01, 2016, 03:37:19 PM »
@Grrr1337 + @Lee Mac: Thanks for the clarification. I guess BricsCAD is a bit more flexible here.
Grrr1337
« Reply #13 on: December 01, 2016, 05:43:47 PM »
Thanks Lee,
I expected that in such particular cases, you might use NP++ (sounds impressive that you push VLIDE to its limits).  :evillaugh:
I was aware about the Format DCL program (and I thought you might used it for this task (before I re-checked its functionality)).
I'll post my idea(inspiration) over the DCL section, when its done. :)
« Reply #14 on: December 01, 2016, 05:58:39 PM »
Completely nuts how a 10 year old post contributed to this thread. :crazy2:
I feel old. :cry:
\|// Set goal. Experiment tirelessly until
|Oo| practice has become expertise.  Loop.
|- | LinkedIn | Dropbox
