Author Topic: file bloat/infection  (Read 12179 times)
Jeff H
Re: file bloat/infection
« Reply #15 on: December 01, 2016, 12:25:55 PM »
Cool! Thank you.
I didn't even realize wblock would do that.
How is wblock doing that?
« Reply #16 on: December 01, 2016, 12:27:48 PM »
« Reply #17 on: December 01, 2016, 02:10:25 PM »
Word to the wise: Set all viewports and all spaces (i.e. model-space, paper-space) to the World Coordinate System (WCS) before using the WBlock cleaning technique (or -ExportToAutoCAD) lest some drawings go wharrgarbl.
Quick test in 2017 & viewports remain unchanged in paperspace so long as the wblock is done from modelspace & set to world.
« Reply #18 on: December 01, 2016, 02:17:01 PM »
... as long as the wblock is done from modelspace & set to world.
Yep. :thumbs_up:
alanjt
  • Standby for witty remark...
« Reply #19 on: December 02, 2016, 09:46:38 AM »
Yep. :thumbs_up:
Same. Only works from model. Pretty cool.
Dropbox
3dwannab
« Reply #20 on: April 07, 2018, 01:35:21 PM »
Thanks.
I've went with this below to create a new file with the suffix _wblocked
(command "_.-wblock" (strcat (getvar 'dwgprefix) (vl-filename-base (getvar "dwgname")) "_wblocked") "*")
