Author Topic: 3dcorbit  (Read 1958 times)
Pintech
3dcorbit
« on: May 17, 2005, 10:20:55 PM »
How do I use the 3d orbit continuos(3dcorbit) in auto lisp?
3dcorbit
« Reply #1 on: May 17, 2005, 11:25:45 PM »
(defun c:test ()
  (command "_line" pause pause "")
  (command "_3dorbit")
  (getpoint "\nSelect point")
This is an example of using it from a user defined function.
.... continuous ?
To my knowledge, drawing commands can't be used while ORBIT is active. It is just used to set the current VIEW.
regards
kwb
3dcorbit
« Reply #2 on: May 17, 2005, 11:50:31 PM »
not sure continuous orbit can be implemented via lisp .... it requires a point, direction vector and speed to determing rotation angle and rotation speed. There MIGHT be something but I wouldn't hold my breath
