Author Topic: Renumerating  (Read 17215 times)
deegeecees
Renumerating
« Reply #15 on: January 05, 2004, 02:35:02 PM »
So, my spelling aint so good, umm, yes, what is your operating status Mr. Water Bear?
AutoCAD version?
Operating System?
Renumerating
« Reply #16 on: January 05, 2004, 02:39:05 PM »
Perhaps something like this would suit ?
kwb
(defun nextductid (/ returnvalue)
  (or #cnt (setq #cnt (getcfg "appdata/MySTUFF/LastDuctID")))
  (or (and #cnt (/= 0 (strlen #cnt)))
      (setq returnvalue (getint "No Duct Number has been saved. Enter New Number :"
            returnvalue (if (= returnvalue "")
                          000
                          (1- returnvalue)
  (if (numberp returnvalue)
    (setq #cnt (itoa(1+ returnvalue)))
    (setq #cnt (itoa(1+ (atoi #cnt))))
  (setcfg "appdata/MySTUFF/LastDuctID" #cnt)
  #cnt
Renumerating
« Reply #17 on: January 05, 2004, 02:42:24 PM »
Kerry, I actually had thought of using that scenario, but if there are multiple drawings, the duct number would be incorrect in a different drawing. I suggest using the system variable USERI1 to store the number since it is an integer and is stored in the drawing when it is saved.
deegeecees
Renumerating
« Reply #18 on: January 05, 2004, 02:43:47 PM »
Oh, sure just give him the whole farm. How will people ever learn to be responsible Lispers if they never learn on their own?
Keb, if another routine uses the USER??? variables when a drawing is opened, he's not going to aquire the correct info from it. The CORRECT way would be the sort through method.
Water Bear
kudos...
« Reply #19 on: January 05, 2004, 02:43:54 PM »
DGCs..thanx, let me work on the ssget "x"
p.s. I noticed right away KEB wuz pulling a chain...hater!
Renumerating
« Reply #20 on: January 05, 2004, 02:46:49 PM »
Huh????I aint pullin no ones chain....I aint got no hands....If'n ya don't want to just replace yer cnt code with my edited one that's fine cuz I just like to code....
an wazzup with hater????
Renumerating
« Reply #21 on: January 05, 2004, 02:47:16 PM »
Perhaps this then
(setcfg (strcat "appdata/MySTUFF/" (getvar "dwgname") "/LastDuctID") "123")
(getcfg (strcat "appdata/MySTUFF/" (getvar "dwgname") "/LastDuctID"))
< added >
Keith ... its just that I loath the "USERxxx" vars :)
daron
Renumerating
« Reply #22 on: January 05, 2004, 02:52:05 PM »
Quote from: KEB
I was wondering the same thing. Guy don't know what he's talking about, I think.
Renumerating
« Reply #23 on: January 05, 2004, 03:19:18 PM »
Ok, Kerry ... just being the devils advocate for a minute.. what happens when he has edited like a thousand drawings....the acad.cfg gets HUGE, plus the drawing cannot be edited across machines effectively...
If you don't like USERxx variables that is ok.. I was simply trying to offer the simplest solution to the problem..
But...
We can still have an internal count (internal to the drawing) that is editable by the program across multiple edits and on different machines at the same time...
(defun CNT ()
  (vl-load-com) ; per the Daron Act
  (if #CNT
     nil
     (if (not(setq #CNT (vlax-ldata-get "DuctCount" "CNT")))
         (setq #CNT 0)
  (setq #CNT (1+ #CNT))
  (vlax-ldata-put "DuctCount" "CNT" #CNT)
Now how is that.....totally portable, usable on R2000+, no external files and simple.
Water Bear
my bad..
« Reply #24 on: January 05, 2004, 03:25:03 PM »
Sorry if I step on any toes..I thought someone was INTENTIONALLY misdirecting me because of inconstistent "USERI1" variables...but the post has since been corrected..my bad, I should have known it was an innocent typo! my apologies to KEB
DGCs:2k4 XP
Renumerating
« Reply #25 on: January 05, 2004, 03:31:01 PM »
Keith :: Yep that works cool.
what's that expression about  lots of ways to pluck a duck :D
An effective solution depends on the project requirements, which we dont know of course.
Personally I would use attributed blocks, then a search is easier, and so is renumbering if you have to.
Water Bear
humm...
« Reply #26 on: January 05, 2004, 03:54:32 PM »
KerryB
That sounds like an interesting alternative (attributes) how would I setup to re-number? What function could I use?
Renumerating
« Reply #27 on: January 05, 2004, 04:03:53 PM »
I like ldata. (I always forget about it too!) I like the idea of an external file, but thats cool. whatever works.
Renumerating
« Reply #28 on: January 05, 2004, 04:03:56 PM »
WB, you would need to use attributed blocks for your numbering scheme, even if it is simply a single attribute with no other objects. You could then filter for the block name and each one would have a unique number. Once the selection of the blocks is completed, you would simply need to use other routines available from this site to update and/or change the numbering.
deegeecees
Another Duck
« Reply #29 on: January 05, 2004, 04:31:56 PM »
How about using xdata. Attach xtended entity data to the entities in question. If they are text entities all the better, just find em and manipulate em.
Quack.
