Author Topic: Return Location @ Selection  (Read 783 times)
quaziconscience
  • .net stuff
« on: November 14, 2016, 11:39:13 PM »
Is there a way to get the coordinate when/where I select an object?  I am using PromptNestedEntityOptions to select my object, but would like to grab the coordinate where I select the object at the same time.
Thanks!
quaziconscience
  • .net stuff
Re: Return Location @ Selection
« Reply #1 on: November 15, 2016, 12:05:21 AM »
  • !false...it's funny 'cause it's true!
« Reply #2 on: November 15, 2016, 12:10:31 AM »
I'm assuming you are catching your prompt result in the PromptNestedEntityResult class and if so you can use the PickedPoint property that this class inherits from PromptEntityResult.
A programmer's wife tells him, "Run to the store and pick up a loaf of bread. If they have eggs, get a dozen."
The programmer comes home with 12 loaves of bread.
quaziconscience
  • .net stuff
« Reply #3 on: November 15, 2016, 12:19:05 AM »
I hate how hard I make things. I actually created a pointmonitor and did some shady stuff to capture the value lol.   Thanks so much!
« Reply #4 on: November 15, 2016, 12:24:02 AM »
No worries :)
huiz
  • Certified Prof C3D
« Reply #5 on: November 15, 2016, 07:15:04 AM »
On the other side you might have learned new things now, so no wasted time :-)
quaziconscience
  • .net stuff
« Reply #6 on: November 15, 2016, 09:42:42 AM »
MWorland
  • Mosquito
« Reply #7 on: April 04, 2019, 09:38:00 PM »
When using promptNestedEntityResult.PickedPoint, I'm not receiving a point that is on the entity I select. For example, if you select an entity from a top view, your Z axis will be 0, not at the elevation of the entity selected.
This gets worse when you select an entity when you are not in an orthogonal view. AutoCAD seems to continue looking for the point until it hits elevation zero
Pick a point a the top in image 01
Point looks ok in Image 02
Point not ok in Image 03
Is there a way to prevent AutoCAD from picking a point past my actual entity?
Thanks,
matt
