Author Topic: variable blank,,!  (Read 7579 times)
hudster
variable blank,,!
« Reply #15 on: May 19, 2005, 07:54:28 AM »
strange, I have 2000 and mine doesn't.
I wonder if there is a variable which controls this?
whdjr
variable blank,,!
« Reply #16 on: May 19, 2005, 08:44:34 AM »
Run this and post the results so we can compare:
(entget (car (entsel)))
whdjr
variable blank,,!
« Reply #17 on: May 19, 2005, 08:49:19 AM »
This is one segment before joining:
Command:(entget (car (entsel)))
Select object:
((-1 . <Entity name: 24f59a8>)
  (0 . "LWPOLYLINE")
  (330 . <Entity name: 24f58f8>)
  (5 . "4D")
  (100 . "AcDbEntity")
  (67 . 0)
  (410 . "Model")
  (8 . "0")
  (100 . "AcDbPolyline")
  (90 . 2)
  (70 . 0)
  (43 . 1.0)
  (38 . 0.0)
  (39 . 0.0)
  (10 12.9965 9.4425)
  (40 . 1.0)
  (41 . 1.0)
  (42 . 0.0)
  (10 12.9965 4.4425)
  (40 . 1.0)
  (41 . 1.0)
  (42 . 0.0)
  (210 0.0 0.0 1.0)
and this is after I joined them using pedit->join:
Select object:
  (0 . "LWPOLYLINE")
  (5 . "4D")
  (67 . 0)
  (410 . "Model")
  (8 . "0")
  (90 . 4)
  (70 . 1)
  (43 . 1.0)
  (38 . 0.0)
  (39 . 0.0)
  (10 12.9965 9.4425)
  (40 . 1.0)
  (41 . 1.0)
  (42 . 0.0)
  (10 12.9965 4.4425)
  (40 . 1.0)
  (41 . 1.0)
  (42 . 0.0)
  (10 7.99653 4.4425)
  (40 . 1.0)
  (41 . 1.0)
  (42 . 0.0)
  (10 7.99653 9.4425)
  (40 . 1.0)
  (41 . 1.0)
  (42 . 0.0)
  (210 0.0 0.0 1.0)
hudster
variable blank,,!
« Reply #18 on: May 19, 2005, 09:20:29 AM »
Unclosed
((-1 . <Entity name: 7ef83088>)
(0 . "LWPOLYLINE")
(330 . <Entity name: 7ef81cf8>)
(5 . "891")
(67 . 0)
(410 . "Model")
(8 . "0")
(90 . 5)
(70 . 128)
(43 . 1.0)
(38 . 0.0)
(39 . 0.0)
(10 119.496 62.0295)
(40 . 1.0)
(41 . 1.0)
(42 . 0.0)
(10 119.496 67.0295)
(40 . 1.0)
(41 . 1.0)
(42 . 0.0)
(10 124.496 67.0295)
(40 . 1.0)
(41 . 1.0)
(42 . 0.0)
(10 124.496 62.0295)
(40 . 1.0)
(41 . 1.0)
(42 . 0.0)
(40 . 1.0)
(41 . 1.0)
(42 . 0.0)
(210 0.0 0.0 1.0))
after closing
(0 . "LWPOLYLINE")
(5 . "891")
(67 . 0)
(410 . "Model")
(8 . "0")
(90 . 5)
(70 . 129)
(43 . 1.0)
(38 . 0.0)
(39 . 0.0)
(40 . 1.0)
(41 . 1.0)
(42 . 0.0)
(40 . 1.0)
(41 . 1.0)
(42 . 0.0)
(40 . 1.0)
(41 . 1.0)
(42 . 0.0)
(40 . 1.0)
(41 . 1.0)
(42 . 0.0)
(40 . 1.0)
(41 . 1.0)
(42 . 0.0)
(210 0.0 0.0 1.0))
Drawn Closed
((-1 . <Entity name: 7ef830a0>)
(0 . "LWPOLYLINE")
(5 . "894")
(67 . 0)
(410 . "Model")
(8 . "0")
(90 . 4)
(70 . 129)
(43 . 1.0)
(38 . 0.0)
(39 . 0.0)
(40 . 1.0)
(41 . 1.0)
(42 . 0.0)
(40 . 1.0)
(41 . 1.0)
(42 . 0.0)
(40 . 1.0)
(41 . 1.0)
(42 . 0.0)
(40 . 1.0)
(41 . 1.0)
(42 . 0.0)
(210 0.0 0.0 1.0))
whdjr
variable blank,,!
« Reply #19 on: May 19, 2005, 09:39:15 AM »
The only thing I can see different is the number of vertices and the pline generation, assoc. codes 90 and 70 respectfully.  I am at a loss here.
Sorry,
daron
variable blank,,!
« Reply #20 on: May 19, 2005, 09:54:07 AM »
see if this one exposes anything a bit more:
(vlax-dump-object (vlax-ename->vla-object (car (entsel))))
hudster
variable blank,,!
« Reply #21 on: May 19, 2005, 10:29:34 AM »
unclosed
; Property values:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00b9b5e4>
;   Area (RO) = 25.0
;   Closed = 0
;   ConstantWidth = 1.0
;   Coordinate = ...Indexed contents not shown...
;   Coordinates = (11.1578 5.62949 11.1578 10.6295 16.1578 10.6295 ... )
;   Document (RO) = #<VLA-OBJECT IAcadDocument 0ab485c0>
;   Elevation = 0.0
;   Handle (RO) = "892"
;   HasExtensionDictionary (RO) = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 096c3674>
;   Layer = "0"
;   Length (RO) = 20.0
;   Linetype = "ByLayer"
;   LinetypeGeneration = -1
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Normal = (0.0 0.0 1.0)
;   ObjectID (RO) = 2130243728
;   ObjectName (RO) = "AcDbPolyline"
;   OwnerID (RO) = 2130238712
;   PlotStyleName = "ByLayer"
;   Thickness = 0.0
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 096c0bc0>
;   Visible = -1
T
closed
; Property values:
;   Area (RO) = 25.0
;   Closed = -1
;   Elevation = 0.0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 0969d1d4>
;   Layer = "0"
;   Lineweight = -1
;   Thickness = 0.0
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 096bbc80>
;   Visible = -1
T
drawn closed
; Property values:
;   Area (RO) = 25.0
;   Closed = -1
;   Elevation = 0.0
;   Handle (RO) = "893"
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 096c0e64>
;   Layer = "0"
;   Lineweight = -1
;   ObjectID (RO) = 2130243736
;   Thickness = 0.0
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 096c06f0>
;   Visible = -1
T
whdjr
variable blank,,!
« Reply #22 on: May 19, 2005, 11:22:34 AM »
Ok Hudster,
I think I figured this out.  I think we're using two different versions of ACAD here.  Your returning a length prop. and a True color prop. which I don't have in A2K.  I started A2k6 and drew the pline without closing it and it looked like the one you showed with the one missing corner.  Even after filleting and joining it, it still did not work.  I listed the "unclosed" and the "closed" pline and this is what I get:
Command: LIST
Select objects: Specify opposite corner: 2 found
Select objects:
                  LWPOLYLINE  Layer: "0"
                            Space: Model space
                   Handle = 1cbc
            Closed
    Constant width   1.00000
              area   25.00000
         perimeter   20.00000
          at point  X=798.62500  Y=965.37500  Z=  0.00000
          at point  X=803.62500  Y=965.37500  Z=  0.00000
          at point  X=803.62500  Y=960.37500  Z=  0.00000
          at point  X=798.62500  Y=960.37500  Z=  0.00000
                            Space: Model space
                   Handle = 1cac
            Closed
              area   25.00000
         perimeter   20.00000
          at point  X=808.43750  Y=960.37500  Z=  0.00000
          at point  X=808.43750  Y=965.37500  Z=  0.00000
          at point  X=813.43750  Y=965.37500  Z=  0.00000
          at point  X=813.43750  Y=960.37500  Z=  0.00000
It appears that when you draw a pline and don't close it, but return it to the original start point AutoCAD adds an extra 0 length line for some reason. :roll:
I did get it to work however; but it's not pretty.
Explode your pline.  Find the one that is a 0 length and delete it.  Then use the pedit command and choose the multiple option and select your 4 lines.  Then choose the join option and then the close option (don't miss the close option or it won't work).  Then choose the width option to set your width and you should be done.
Command: e
ERASE 1 found
Command: pedit
Select polyline or [Multiple]: m
Select objects: Specify opposite corner: 4 found
Select objects:
Convert Lines and Arcs to polylines [Yes/No]? <Y> y
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: j
Join Type = Extend
Enter fuzz distance or [Jointype] <0.00000>:
3 segments added to polyline
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: c
Enter an option [Close/Open/Join/Width/Fit/Spline/Decurve/Ltype gen/Undo]: w
Specify new width for all segments: 1
There are better options such as erase and redraw it closed or us the pljoin command from the expresstools if you have it.
I hope this helps everyone,
hudster
variable blank,,!
« Reply #23 on: May 19, 2005, 11:37:36 AM »
We use 2000 and Lt2000, and it draws these OK on some machines but not on others, I just wondered why, and if there was a variable which controlled this.
edit.
if I draw the last segment as 4mm rather than 5mm and then close it using pedit, it adds a 1mm segment, and doesn't have the notch out the corner.
Now the question is, why does it draw that last segment rather than just extending the last one.
whdjr
variable blank,,!
« Reply #24 on: May 19, 2005, 11:44:55 AM »
Ok, this is strange.  I just tried it again in A2K and it did not work correctly; however I tried this routine by Kerry Brown on it and presto all was good.  It will remove the extra vertex if you select the "bad" corner.
