Author Topic: vlax-3D-point to list  (Read 5971 times)
« on: May 17, 2005, 03:19:06 PM »
If you use this (vlax-3D-point list) to create a vlax point
How do you reverse the process?
« Reply #1 on: May 17, 2005, 03:28:51 PM »
(vlax-safearray->list (vlax-variant-value (vlax-3D-point '(0 0 0))))
« Reply #2 on: May 17, 2005, 03:35:45 PM »
Well you can tell I don't use that one very often. :oops:
You would think the help file would have a clue in the vlax-3D-point command
as to how to reverse the process. Oh well.
Thanks Michael
Jürg Menzi
  • Oberegg, Switzerland
« Reply #3 on: May 18, 2005, 02:16:49 AM »
Hi CAB
You can also use the VitalLisp part of ActiveX:
(vla-get-StartPoint Obj)
;can be replaced by:
(vlax-get Obj 'StartPoint)
;and returns directly a list...
or:
(vla-put-StartPoint Obj (vlax-3D-point '(0 0 0)))
(vlax-put Obj 'StartPoint '(0 0 0))
Cheers
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
« Reply #4 on: May 18, 2005, 08:11:15 AM »
Thanks for the help Jürg, very informative.
That reminds me that ther was a thread about the difference in the two methods.
Now if I can only find it. 8)
« Reply #5 on: May 18, 2005, 08:20:45 AM »
OK, here it is.
Your example sparked my dim memory of this post. :)
http://www.theswamp.org/phpBB2/viewtopic.php?t=620&highlight=vlaxput
SMadsen
« Reply #6 on: May 18, 2005, 08:20:57 AM »
Always wondered about the exact origin of those functions. Good info. Thanks mr. Menzi.
« Reply #7 on: May 18, 2005, 08:28:46 AM »
I wish Autodesk never bought Vital LISP from BASIS Software. Vital LISP today would kick Visual LISP's butt around the block (Autodesk have let it languish), we'd have actual secure output (arx) and you wouldn't have to run it inside AutoCAD.
/rant
« Reply #8 on: May 18, 2005, 08:56:28 AM »
I agree MP. I still have my original manuals around here somewhere.
I recall the disappointment I felt with each subsequent release by AutoDesk when nothing was done to expand on the work BASIS did on the product.
« Reply #9 on: May 18, 2005, 09:59:29 AM »
I still remember getting version 2 and rubbing me hands gleefully "Excellent Smithers, let's bash some serious apps out, w00t!". Last version I had round here was 3 Professional (IIRC). Now where are those manuals ...
... 'Course, I remember AutoDIRECT too. Man, time flies ...
SMadsen
« Reply #10 on: May 18, 2005, 10:05:59 AM »
Quote from: Kerry Brown
I suppose they are printed manuals? If so, you know how OCR scanning works, right?  :wink:
