Author Topic: R2006 Tips for Upgrading  (Read 3029 times)
Wyatt Earp
« on: May 17, 2005, 02:17:57 PM »
Just wanted to get a thread started that discussed the upgrade from R200* to R2006.
Things to post here would be Sysvar's, links to XML editors and any little thing you've stumbed across.
I have a growing list and will complie as time permits.
Cheers
CADaver
« Reply #1 on: May 17, 2005, 02:53:11 PM »
I'm waiting to hear this one.  My R2006 was waiting for me last night when I got home.
« Reply #2 on: May 17, 2005, 02:58:46 PM »
I used XmlSpy a fair amount 4 years ago and it was great.
Wyatt Earp
« Reply #3 on: May 17, 2005, 02:59:01 PM »
Huh?
What's there to hear?
I'm reading all kinds of things from different sources and I find it weird that AutoDESK hasn't put out a paper on it yet as it looks kind of weird. I haven't performed my upgrade yet but i've played with it a bit.
CADaver
« Reply #4 on: May 17, 2005, 04:50:52 PM »
Quote from: Wyatt Earp
Huh?
I have roughly 25 heavily customized menus in R2002 that will need transportation into CUI format, and I'm wondering just how big a hole has been shot in my foot.
Wyatt Earp
« Reply #5 on: May 17, 2005, 04:52:57 PM »
I'm the same way and I'm going to say BIG.
nivuahc
« Reply #6 on: May 17, 2005, 09:16:33 PM »
HUGE
t-bear
« Reply #7 on: May 17, 2005, 09:29:32 PM »
Oh boy....here I go again!
« Reply #8 on: May 18, 2005, 10:05:14 AM »
Cadaver,
I just did a menuload in 2006 with my custom.mns and it ported it over to a cui file. from what I can see, everything is working fine.
Ron
Wyatt Earp
« Reply #9 on: May 18, 2005, 11:12:54 AM »
It might work ok, but from what i've read so far it depends on which order you import them, it depends on which order they are listed - esp. if you are working on a network as i am. also note that again from what i've read once you make the transformation you can't get it back so make a backup first.
« Reply #10 on: May 18, 2005, 11:16:34 AM »
When I menuloaded it did not overwrite my mns, it made another file with the same name but with a cui extension. :?:
Ron
ML
« Reply #11 on: May 18, 2005, 11:51:05 AM »
The big difference besides all of the aforementioned in 2006 is that there is now Enterprise and Main paths that need to be set.
If you are sharing a company cui file on a shared network, path all users to it as Enterprise.
If you manage the company cui, path to it as Main, so that you can customize it.
David Hall
  • Automatic Duh Generator
« Reply #12 on: May 18, 2005, 12:26:16 PM »
I just loaded mine in using menuload and it came across fine.  I kept my mns file and I make updates to it and just reload it like i used to.  I HATE the new cui editor.  Dont be fooled by its simplacy, it SUCKS!  In a nutshell, I had a toolbar with 2 of the same images, but they had different macros. (Think Plot FullSize and HalfSize).  I went in to edit 1 of the macros, and because the picture was the exact same, it changed the second macro to match the first.  Well, isn't that just great! So I logged the problem w/ Autodork, and the response I got was "Its functioning the way it was designed".  Needless to say, I told the tech at Autodork that was about the biggest, worthless improvement to 2006 I had come across.
ML
« Reply #13 on: May 18, 2005, 03:14:14 PM »
Hey CM
When we first got it here, I felt the same way that you do but I have a good grasp on it now. If you have any questions, just ask or PM me.
A few tips:
 If you update the company menu, make 2  profiles, one with
acad.cui as main and the company.cui file as enterprise.
The second one, just reverse it. Company as main, acad as enterprise.
Also, your workspace is a key factor. Select the option, do not save changes to Workspace, it can be a pain in the *. If you make a workspace change, you the pulldown, saveas and overwrite the old one.
ML
« Reply #14 on: May 18, 2005, 04:34:44 PM »
CM
You don't want to do it that way.
After you menu(cui)load your mns file, you need to create a workspace so that you can customize it.
Well, if you keep menuloading over and over, you will overwrite the cui file and workspace each time.
In the cui editor, you can probably load the mns (converts to cui) and transfer the changes to the existing cui file. If that works, I would suggest that approach over the constant menuload approach
