Author Topic: Prompt User for Lisp Choice with Lisp.  (Read 902 times)
michilson
« on: October 20, 2016, 11:37:57 AM »
Hi guys,
I am new to the whole lisp function. However I can write scripts and macros.
So here's what I'm looking to develop for a new company I am working for. I want to prompt a user to choose a lisp with a auto lisp.
(Working on Project 1) You choose the Project 1 Lisp (Setting layers, line types, Dim Styles etc) for that project.
And the same for Project 2 and so on.
So this would display a prompt on a Qnew allowing you to choose a lisp for new drawings.
Thanks for the help guys!
Mike
MSTG007
Re: Prompt User for Lisp Choice with Lisp.
« Reply #1 on: October 20, 2016, 03:10:32 PM »
I would try sticking to scripts (SCR) for setups. Easy to write up too. Then you can call lisps through the script.
Civil3D 2020
ifncdylan
« Reply #2 on: October 20, 2016, 09:09:16 PM »
Sounds like standards might be applicable here. You can write a template file and then set it as a standard and it will ensure your drawings use only those styles etc in the standard template.
You won't need a lisp for that, just replace the standards file :)
