Author Topic: ZWCAD SHP file  (Read 2777 times)
sigster
ZWCAD SHP file
« on: October 16, 2016, 08:16:33 AM »
Hi
I was testing ZWCAD and it is no SHP Inport
Have anyone try to use one of this to import SHP file to CAD
http://www.easygisdotnet.com/
https://dotspatial.codeplex.com
sigster
Re: ZWCAD SHP file
« Reply #1 on: October 21, 2016, 10:00:41 PM »
I got a little help, this is what I have but it draw one long line
how can I end each Polyline
  <CommandMethod("XY")> _
        Public Sub readxy()
            Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                Dim acBlkTbl As BlockTable
                acBlkTbl = CType(acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead), BlockTable)
                Dim acBlkTblRec As BlockTableRecord
                acBlkTblRec = CType(acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite), BlockTableRecord)
                Dim shapeActual As FeatureSet = FeatureSet.Open("PATH\FILE.shp")
                shapeActual.FillAttributes()
                Dim dt As System.Data.DataTable = shapeActual.DataTable
                Dim pline As Polyline = New Polyline()
                pline.SetDatabaseDefaults()
                For count As Integer = 0 To shapeActual.Features.Count - 1
                    For Each feature As IFeature In shapeActual.Features 'circle through the features
                        For i As Integer = 0 To feature.BasicGeometry.NumGeometries - 1 'circle through the parts of one feature
                            For Each coord As Coordinate In feature.BasicGeometry.GetBasicGeometryN(i).Coordinates() 'circle through the coordinates of the feature part
                                Dim AdresX = coord.X
                                Dim AdresY = coord.Y
                                pline.AddVertexAt(count, New Point2d(coord.X, (coord.Y + 1)), 0.0, 0.0, 0.0)
                                count = count + 1
                                ed.WriteMessage(vbCr & count)
                                ed.WriteMessage(vbCr & feature.FeatureType.ToString)
                            Next
                        Next
                    Next
                Next
                acBlkTblRec.AppendEntity(pline)
                acTrans.AddNewlyCreatedDBObject(pline, True)
                acTrans.Commit()
            End Using
        End Sub
MickD
Re: ZWCAD SHP file
« Reply #2 on: October 21, 2016, 10:16:26 PM »
do you mean 'close' each pline? If so use pline.Close() to make a closed polyline (no gaps)
- John Carmack
- J.R.R. Tolkien
sigster
Re: ZWCAD SHP file
« Reply #3 on: October 22, 2016, 04:10:47 AM »
Do you mean  pline.Closed = True   already try it
the Image I upload show House line I insert
1. how it insert one line
2. manual delete extra line
MickD
Re: ZWCAD SHP file
« Reply #4 on: October 22, 2016, 06:15:40 PM »
Ahh, ok. It looks lie you need to find the start/end pairs of the geometry data.
can you attach your shp sample file so I can have a look?
- John Carmack
- J.R.R. Tolkien
sigster
Re: ZWCAD SHP file
« Reply #5 on: October 23, 2016, 09:40:25 AM »
This is SHP sample
MickD
Re: ZWCAD SHP file
« Reply #6 on: October 23, 2016, 06:50:13 PM »
Hi sigster,
I was hoping to be able to read the shp file but it's binary, I also looked at the MAP help doc's which were almost useless (to me anyway without knowing the product) but after looking at the picture a bit I would try to just add line segments, not a polyline and see what you get.
That is, instead of appending a vertex every point, create a line after every second point. In other words, split the vertex list into tuples of 2 points and create a line for each tuple, hope that makes sense?
It probably won't be what you want but it may lead to some clues.
Can you point to some online help for the "FeatureSet" library/api you are using?
« Last Edit: October 23, 2016, 06:54:52 PM by MickD »
- John Carmack
- J.R.R. Tolkien
sigster
Re: ZWCAD SHP file
« Reply #7 on: October 23, 2016, 07:32:18 PM »
