Author Topic: Layer States  (Read 3178 times)
wya11
Layer States
« on: October 12, 2016, 11:35:01 AM »
Hi there,
I am brand new to the Swamp. I was directed here from a member on Reddit where I asked this question.
I've been using AutoCad for a while now and although I am pretty experienced, I have zero experience creating lisp's, which I am told may be a solution for me. At a previous job I used Vectorworks and was easily able to switch between "saved views" with two key strokes. The AutoCad equivalent is of course Layer States. I'm just wondering if someone has or could help me set up a hotkey to scroll through different Layer States at my work.
I hope this makes sense and thank you for any help!
Thanks,
W
Re: Layer States
« Reply #1 on: October 12, 2016, 11:44:16 AM »
Welcome to the Swamp.
I am using an older version of ACAD so I will not be up to speed on Layer States Manager. I currently find the Express Tools version of the layer manager more to my liking.
Re: Layer States
« Reply #2 on: October 12, 2016, 12:28:10 PM »
You can learn what has been done here "Layer States"
Creating  Up/Down buttons for stepping through the saved layer states is doable.
« Last Edit: October 12, 2016, 12:35:16 PM by CAB »
Dommy2Hotty
Re: Layer States
« Reply #3 on: October 14, 2016, 09:40:45 AM »
In addition to all of the extremely helpful people here on TheSwamp.org (CAB is definitely one!), I gained great LISP knowledge from AfraLISP.net.  Excellent explanations & exercises that start at the most basic (Hello World!) and work up to the most advanced uses of LISP.
Re: Layer States
« Reply #4 on: October 14, 2016, 12:21:01 PM »
W,
I just ran across this Bricsys CAD tutorial that did almost what you want with a tool Bar.
https://www.bricsys.com/tv/m/?employing-the-display-power-of-layer-states-m268
You may be able to do same in ACAD.
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: Layer States
« Reply #5 on: October 14, 2016, 06:29:47 PM »
The ACAD.PGP has a hotkey shortcut LMAN
LMAN,      *LAYERSTATE
Once in the dialog scrolling is available ...
Or did you mean to ask for something else ??
Welcome to TheSwamp.
added:
or from the menu
Home->Layers->
« Last Edit: October 14, 2016, 06:33:02 PM by kdub »
Called Kerry in my other life
I live at UTC + 13.00
Re: Layer States
« Reply #6 on: October 15, 2016, 08:51:26 AM »
So from that you could create you own button to pull up the dialog.
Not quite the same as up/down buttons but better to scroll the list IMO.
kdub_nz
  • SuperMod
Re: Layer States
« Reply #7 on: October 15, 2016, 07:56:39 PM »
Hi Alan
The functionality is quite adequate and versatile.
The only time I program with Layer States is to setup default states in new drawings or repair states in established drawings.
The menu list populates in a usable manner.
added:
I like what they're doing with BricsCad; they have always seemed to care about their users and developers.
« Last Edit: October 15, 2016, 07:59:49 PM by kdub »
Re: Layer States
« Reply #8 on: October 16, 2016, 06:54:51 PM »
Yes that looks quite adequate. Using ACAD2006 the Layer manager was not fully developed so I use Express tools version extensively.
I see in newer versions 2012+ it auto updates from ET LM to get you current. Only thing would like to see is a pulldown like the layer changer but for layer states.
I purchased BrcisCAD V16 but have not jumped into it with both feet.
My current workload is overwhelming me & no free time to get acquainted with the new software.
I have set up all my buttons & menu's and need to start testing my LISP library.
Re: Layer States
« Reply #9 on: October 16, 2016, 07:11:28 PM »
Just created this in BricsCAD
lamarn
Re: Layer States
« Reply #10 on: October 17, 2016, 02:59:46 AM »
Awesome 🙆 CAB
dtkell
Re: Layer States
« Reply #11 on: October 17, 2016, 12:30:35 PM »
ACAD also has the ability to save layer states within the View Manager (VIEW) or on the View tab of the Ribbon. It even has its own toolbar (if anyone still uses those.)
\"What sane person could live in this world and not be crazy?\" -Ursula K. Le Guin
danallen
Re: Layer States
« Reply #12 on: October 17, 2016, 01:04:41 PM »
what's the panama ball drop? sounds interesting
Re: Layer States
« Reply #13 on: October 17, 2016, 02:35:55 PM »
Not to be out done by NYC Panama City is creating there own New Years Spectacle.
At 80' tall it should be something to see.
« Last Edit: October 17, 2016, 02:40:05 PM by CAB »
danallen
Re: Layer States
« Reply #14 on: October 17, 2016, 02:51:15 PM »
cool, thanks for sharing! drawing needs a scale figure... I like the "micro" anchors and then realize that to scale those must be taller than my house!
