Author Topic: Pipe Can't make type "Tee...  (Read 1071 times)
hudster
« on: October 12, 2016, 06:07:02 AM »
I'm having a weird issue with a model.
I'm trying to trim/extend a pipe to tee into another pipe, they are both at the same level, but I get the "Can't make type "Tee Branch....."" error. However, if I extend the pipework so its less than 1 metre from the pipe I want to connect to, it trim/extens with no error message.
Anyone know whats causing this? and how to fix it
Rob...
Re: Pipe Can't make type "Tee...
« Reply #1 on: October 12, 2016, 06:35:41 AM »
Does it make the tee when trim/extend works?
Do you have a fitting selected for tees in pipe routing settings?
CAD Tech
hudster
« Reply #2 on: October 12, 2016, 10:04:11 AM »
It wont make the tee, until I manually lengthen the pipe, then it will.
All routing preferences are set.
I ended up deleting all the offending pipes and redrawing them, now it works.
Weird one.
