Now I am facing a problem,I use database.SaveAs function to save a dwg file,but the dwg file do not have an thumbnail image,so I trid to search kean's blog ,and I write code like below,but I can't get what I want.
[CommandMethod("SendSaveAsCmd", CommandFlags.Session)]
public static void DoSaveAs()
string filepath = @"C:\Users\FL_DRAWING\Desktop\Images\1.dwg";
string targetpath = @"C:\Users\FL_DRAWING\Desktop\Images\newdwg.dwg";
Document doc = Application.DocumentManager.Open(filepath, false);
doc.LockDocument();
Database db = doc.Database;
object ocmd = Application.GetSystemVariable("CMDECHO");
string newpath = targetpath.Replace("\\", "/");
string cmd =
"(setvar \"CMDECHO\" 0)" +
"(command \"_.SAVEAS\" \"\" \"" + newpath + "\")" +
"(setvar \"CMDECHO\" " + ocmd.ToString() + ")" +
"(princ) ";
doc.SendStringToExecute(cmd,false,false,false);
doc.CloseAndDiscard();
And I tried Another way like below
[CommandMethod("SaveThumbnail", CommandFlags.Session)]
public static void DoSaveThumbnail()
Document doc = Application.DocumentManager.Open(filepath);
doc.LockDocument();
db.RetainOriginalThumbnailBitmap = true;
Bitmap thumb = db.ThumbnailBitmap;
db.ThumbnailBitmap = thumb;
db.SaveAs(targetpath, DwgVersion.Current);
But the thumb is null in line Bitmap thumb = db.ThumbnailBitmap
In one of kean's blog ,I saw Document.CapturePreviewImage
So I rewrite my code like below
doc.LockDocument();
Bitmap thumb = doc.CapturePreviewImage(320, 240);
And I get a thumbnail image with a black background, but the thumbnail could not fullfill the thumbnail in Windows document viewer.And I also could not see clear in Windows Document viewer.
Any help will be great, thank you.
