Author Topic: Can't locate error  (Read 1745 times)
zombies640
Can't locate error
« on: September 26, 2016, 11:01:52 AM »
How this is supposed to work is the user will first select objects, then run the command. The routine will determine if either "DEC" or "CNF" is in the point description. If it is, place a block and some text.
Not sure why this is giving me an error now. It looks like it only errors after the IF statement triggers TRUE:
Command: ; error: no function definition: nil
(defun c:desc2 (/ ss x northng pnt eastng descr)
   (if (ssget ":S:E" '((0 . "AECC_COGO_POINT")))
         (vlax-for x
            (setq ss (vla-get-activeselectionset (vla-get-activedocument (vlax-get-acad-object))))
            (setq pnt (vlax-get x 'number)
               eastng (vlax-get x 'easting)
               northng (vlax-get x 'northing)
               descr (vlax-get x 'rawdescription)
            );END setq
               (or
                  (= 0 (vl-string-search "DEC" descr))
                  (= 0 (vl-string-search "CNF" descr))
               );END or
                  (command "text" "c" (list eastng northng) 0.5 0 descr)
                  (command "-insert" "nf_shrub_conifer" (list eastng northng) "" "" "")
               );END if TRUE
            );END if
         );END vlax-for
      );END progn
   );END if
ribarm
  • Marko Ribar, architect
Re: Can't locate error
« Reply #1 on: September 26, 2016, 11:22:33 AM »
Can't test it as I don't have Civil, but I suppose you forgot to put (progn after (if (condition)...
         (vlax-for x
            );END setq
               (or
               );END or
               );END if TRUE
            );END if
         );END vlax-for
      );END progn
   );END if
M.R. on Youtube
zombies640
« Reply #2 on: September 26, 2016, 11:27:41 AM »
Yup, that works. As you were replying, I was trying this instead
Changed:
               );END if TRUE
To:
                    "_insert" "nf_shrub_conifer" (list eastng northng) "" "" ""
               );END if true
I like your method better...it's so much celaner. I didn't know you had to use PROGN for separate commands. Now I know! Thanks :)
ribarm
« Reply #3 on: September 26, 2016, 12:09:20 PM »
You're welcome...
BTW. The code you posted looks like there already was written progn, but someone deliberately or not removed it from apparent place inside it...
M.R. on Youtube
PKENEWELL
« Reply #4 on: September 27, 2016, 09:38:49 AM »
NOTE: The (progn) function is is used to combine multiple programming statements into a single output. The reason you have to use it in the IF statement is because IF can only evaluate 1 output for each If / Then and Else combination.
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
alanjt
  • Standby for witty remark...
« Reply #5 on: September 27, 2016, 10:07:06 AM »
Dropbox
