Author Topic: Get characters between "." and "," in a string... STUMPED  (Read 6435 times)
Re: Get characters between "." and "," in a string... STUMPED
« Reply #15 on: September 19, 2016, 06:06:03 PM »
  1. (defun f (d s / i)
  2.   ;;(setq d ":;," s "A:B,C;D")
  3.   ;;(f d s)
  4.   (cond ((= d "") (list s))
  5.         ((setq i (vl-string-position (ascii d) s))
  6.          (append (f (substr d 2) (substr s 1 i)) (f d (substr s (+ 2 i))))
  7.         )
  8.         ((f (substr d 2) s))
  9.   )
  10. )
This reminds me of the form of recursion used when implementing the quicksort algorithm - very good Evgeniy  :-)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #16 on: September 20, 2016, 02:46:38 AM »
Hello Lee!
You have a great memory ;)
Marc'Antonio Alessi
  • Marco
« Reply #17 on: September 20, 2016, 03:51:18 AM »
Recursion is beautiful (very) but often is slower...
(defun AM1 (d s / n c p e l)
  (setq
    c (substr d 1 1)  n c
    n (repeat (strlen d) (setq n (strcat c n)))
    s (vl-string-translate d n s)
    c (ascii c)       p 0
    e (vl-string-position c s)
  (while e
    (setq
      l (cons (substr s (1+ p) (- e p)) l)
      p (1+ e) e (vl-string-position c s p)
  (reverse (cons (substr s (1+ p)) l))
(setq Keys ":;," String "A:B,C;D")
Benchmark.lsp | © 2005 Michael Puckett | All Rights Reserved
Elapsed milliseconds / relative speed for 131072 iteration(s):
    (AM1 KEYS STRING)................1703 / 1.83 <fastest>
    (AM1 KEYS STRING)................1704 / 1.82
    (_StringSplit3 KEYS STRING)......1766 / 1.76
    (_StringSplit3 KEYS STRING)......1781 / 1.75
    (_StringSplit1 KEYS STRING)......1875 / 1.66
    (_StringSplit1 KEYS STRING)......1906 / 1.63
    (F KEYS STRING)..................2359 / 1.32
    (F KEYS STRING)..................2360 / 1.32
    (_StringSplit2 KEYS STRING)......3015 / 1.03
    (F1 KEYS STRING).................3046 / 1.02
    (_StringSplit2 KEYS STRING)......3094 / 1
    (F1 KEYS STRING).................3109 / 1 <slowest>
(setq Keys ":;," String "A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:A:B,C;D:")
Elapsed milliseconds / relative speed for 16384 iteration(s):
    (AM1 KEYS STRING)................1438 / 4.42 <fastest>
    (AM1 KEYS STRING)................1453 / 4.38
    (_StringSplit1 KEYS STRING)......2235 / 2.85
    (_StringSplit3 KEYS STRING)......3266 / 1.95
    (_StringSplit3 KEYS STRING)......3312 / 1.92
    (_StringSplit2 KEYS STRING)......5671 / 1.12
    (_StringSplit2 KEYS STRING)......5750 / 1.11
    (F KEYS STRING)..................5797 / 1.1
    (F KEYS STRING)..................5813 / 1.09
    (F1 KEYS STRING).................6297 / 1.01
    (F1 KEYS STRING).................6359 / 1 <slowest>
(setq Keys ":;," String "A1234567890asdfghjklòasdfghjklò:Bybqwuybquyqwbiu89897879,Csdkjsdkjsdjk3443;Duyyuwe878723ijiu")
(repeat 4 (setq String (strcat String ";" String))
    (AM1 KEYS STRING).................1532 / 12.07 <fastest>
    (AM1 KEYS STRING).................1609 / 11.49
    (F KEYS STRING)...................3437 / 5.38
    (F KEYS STRING)...................3453 / 5.35
    (_StringSplit2 KEYS STRING).......4516 / 4.09
    (_StringSplit2 KEYS STRING).......4609 / 4.01
    (_StringSplit3 KEYS STRING)......15906 / 1.16
    (F1 KEYS STRING).................16375 / 1.13
    (F1 KEYS STRING).................16454 / 1.12
    (_StringSplit1 KEYS STRING)......17609 / 1.05
    (_StringSplit1 KEYS STRING)......18485 / 1 <slowest>
Test order:
(Benchmark '(
(_StringSplit1 Keys String)
(_StringSplit2 Keys String)
(_StringSplit3 Keys String)
(AM1 Keys String)
(f   Keys String)
(f1  Keys String)
(AM1 Keys String)
(f   Keys String)
(f1  Keys String)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #18 on: September 20, 2016, 05:50:57 AM »
Hello Marc!
Yes!
Recursion is very slow.
The new version only for speed...
  1. (defun f3 (d s / i)
  2.   (foreach a (vl-string->list d)
  3.     (while (setq i (vl-string-position a s)) (setq s (vl-string-subst "\"\"" (chr a) s)))
  4.   )
  5.   (read (strcat "(\"" s "\")"))
  6. )
VovKa
  • Ukraine
« Reply #19 on: September 20, 2016, 06:22:22 AM »
(f3 "." "A.B\"C.D")
VovKa
  • Ukraine
« Reply #20 on: September 20, 2016, 06:26:43 AM »
speed of some functions depends on the length of both arguments
try increasing the length of delimiters also
Marc'Antonio Alessi
  • Marco
« Reply #21 on: September 20, 2016, 06:36:24 AM »
Hello Marc!
Yes!
  4.   )
  6. )
Read in some strings get error:
(read (strcat "(\"" "\".ABC" "\")")) =>; errore: punto in posizione non corretta nell'input
Marc'Antonio Alessi
  • Marco
« Reply #22 on: September 20, 2016, 07:07:30 AM »
New test:
(setq Keys ":;,123456789abcd" String "A1234567890asdfghjklòasdfghjklò:Bybqwuybquyqwbiu89897879,Csdkjsdkjsdjk3443;Duyyuwe878723ijiu")
Elapsed milliseconds / relative speed for 32768 iteration(s):
    (AM1 KEYS STRING)................1781 / 9.61 <fastest>
    (AM1 KEYS STRING)................2329 / 7.35
    (_STRINGSPLIT1 KEYS STRING)......4547 / 3.76
    (_STRINGSPLIT1 KEYS STRING)......4890 / 3.5
    (_STRINGSPLIT3 KEYS STRING)......4922 / 3.48
    (_STRINGSPLIT3 KEYS STRING)......5468 / 3.13
    (F1 KEYS STRING).................6469 / 2.64
    (F1 KEYS STRING).................6750 / 2.53
    (F KEYS STRING)..................9844 / 1.74
    (F KEYS STRING).................10546 / 1.62
    (_STRINGSPLIT2 KEYS STRING).....16625 / 1.03
    (_STRINGSPLIT2 KEYS STRING).....17110 / 1 <slowest>
(repeat 4 (setq String (strcat String ";" String)))
Elapsed milliseconds / relative speed for 2048 iteration(s):
    (AM1 KEYS STRING)................1203 / 21.74 <fastest>
    (AM1 KEYS STRING)................1468 / 17.82
    (_STRINGSPLIT1 KEYS STRING)......4093 / 6.39
    (_STRINGSPLIT1 KEYS STRING)......4562 / 5.73
    (_STRINGSPLIT3 KEYS STRING)......5093 / 5.14
    (_STRINGSPLIT3 KEYS STRING)......5735 / 4.56
    (F KEYS STRING)..................9985 / 2.62
    (F KEYS STRING).................12672 / 2.06
    (_STRINGSPLIT2 KEYS STRING).....19579 / 1.34
    (_STRINGSPLIT2 KEYS STRING).....21281 / 1.23
    (F1 KEYS STRING)................24094 / 1.09
    (F1 KEYS STRING)................26157 / 1 <slowest>
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #23 on: September 20, 2016, 11:40:38 AM »
new version, оnly for the sake of comparison, the speed...
  1. (defun f5 (d s / I L)
  2.     (foreach a (VL-STRING->LIST d) (setq l (cons (1+ (VL-STRING-POSITION a s)) l)))
  3.     (setq d 1
  4.           l (vl-sort l (function <))
  5.     )
  6.                                 (setq i d
  7.                                       d (1+ a)
  8.                                 )
  9.                                 (substr s i (- a i))
  10.                               )
  11.                     )
  12.                     l
  13.             )
  14.             (list (substr s d))
  15.     )
  16.   )
I do not like such a long code.  :?
Marc'Antonio Alessi
  • Marco
« Reply #24 on: September 20, 2016, 01:14:51 PM »
I get error in second sample:
Comando: (setq Keys ":;," String "A:B,C;D")
"A:B,C;D"
Comando: (f5  Keys String)
("A" "B" "C" "D")
Comando: (setq Keys ":;,123456789abcd" String "A1234567890asdfghjklòasdfghjklò:Bybqwuybquyqwbiu89897879,Csdkjsdkjsdjk3443;Duyyuwe878723ijiu")
; errore: tipo di argomento errato: numberp: nil
Comando: (f1  Keys String)
("A" "" "" "" "" "" "" "" "" "0" "s" "fghjklò" "s" "fghjklò" "By" "qwuy" "quyqw" "iu" "" "" "" "" "" "" "" "" "Cs" "kjs" "kjs" "jk" "" "" "" "" "Duyyuwe" "" "" "" "" "" "ijiu")
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #25 on: September 20, 2016, 01:35:16 PM »
Thank you!
I corrected the mistake...
  1. (defun f6 (d s / I L)
  2.     (foreach a (VL-STRING->LIST d) (setq l (cons (VL-STRING-POSITION a s) l)))
  3.     (setq d 1
  4.           l (vl-sort (vl-remove nil l) (function <))
  5.     )
  6.                                 (setq i d
  7.                                       d (1+ a)
  8.                                 )
  10.                               )
  11.                     )
  12.                     l
  13.             )
  15.     )
  16.   )
« Reply #26 on: September 20, 2016, 01:39:43 PM »
_$ (f5 ";," "A;B,C;D,E")
("A" "B" "C;D,E")
_$ (f6 ";," "A;B,C;D,E")
("" ";" ",C;D,E")
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #27 on: September 20, 2016, 02:08:12 PM »
  1. (defun f7 (d s / I L)
  3.     (setq i 0)
  4.     (while (setq i (VL-STRING-POSITION a s (1+ i))) (setq l (cons (1+ i) l)))
  5.   )
  6.   (setq d 1
  7.         l (vl-sort (vl-remove nil l) (function <))
  8.   )
  9.                               (setq i d
  10.                                     d (1+ a)
  11.                               )
  12.                               (substr s i (- a i))
  13.                             )
  14.                   )
  15.                   l
  16.           )
  17.           (list (substr s d))
  18.   )
  19. )
« Reply #28 on: September 20, 2016, 02:26:52 PM »
_$ (f7 ";," ",A;B,C;D,E;")
(",A" "B" "C" "D" "E" "")
[sorry]
Marc'Antonio Alessi
  • Marco
« Reply #29 on: September 20, 2016, 02:54:48 PM »
f5 was faster...
(setq Keys ":;,123456789abcd" String "A1234567890absdfghjklòasdfghjklò:Bybqwuybqcuyqwbiu89897879,Csdkjsdkjsdjk3443;Duyyuwe878723ijiu")
    (F5 KEYS STRING)..................1219 / 325.2 <fastest>
    (F5 KEYS STRING)..................1235 / 320.99
    (AM1 KEYS STRING)................20016 / 19.81
    (AM1 KEYS STRING)................20047 / 19.77
    (_STRINGSPLIT1 KEYS STRING)......67750 / 5.85
    (_STRINGSPLIT1 KEYS STRING)......68172 / 5.82
    (_STRINGSPLIT3 KEYS STRING)......84281 / 4.7
    (_STRINGSPLIT3 KEYS STRING)......84344 / 4.7 <slowest>
    (AM1 KEYS STRING)...............1281 / 4.29 <fastest>
    (AM1 KEYS STRING)...............1313 / 4.19
    (F7 KEYS STRING)................2313 / 2.38
    (F7 KEYS STRING)................2390 / 2.3
    (_STRINGSPLIT1 KEYS STRING).....4188 / 1.31
    (_STRINGSPLIT1 KEYS STRING).....4375 / 1.26
    (_STRINGSPLIT3 KEYS STRING).....5390 / 1.02
    (_STRINGSPLIT3 KEYS STRING).....5500 / 1 <slowest>
