Author Topic: Support Path  (Read 1773 times)
cadman6735
Support Path
« on: September 12, 2016, 09:58:20 AM »
Good day,
I have found two very good lisp routines for removing and adding paths to the support file search path but what I am wondering is if anyone has a routine that simply changes Drive letters for all of their paths under the "Files" tab for Options?
Say I wanted to change all the W:\ to S:\ or change the S:\ to the UNC path.  Just search for the desired drive letter and switch it to the new one?
kpblc
Re: Support Path
« Reply #1 on: September 12, 2016, 10:15:11 AM »
As a start simple code
Call sample: (convert-paths "w:" "\\\\server")
Sorry for my English.
cadman6735
Re: Support Path
« Reply #2 on: September 12, 2016, 10:38:19 AM »
Kpblc
thank you
Chillme1
  • Must learn to earn!
Re: Support Path
« Reply #3 on: September 14, 2016, 05:25:09 PM »
Where can I find those support file lisp routines that you refer to? :?
Thanks, Clint
Mechanical Designer / Process Piping
AutoCAD Toolsets 2022
Newbie Betimes - LISP Programmer
