Author Topic: Strange "thing" in layout tab. What is it?  (Read 6718 times)
Re: Strange "thing" in layout tab. What is it?
« Reply #15 on: September 12, 2016, 12:28:55 PM »
anyone have a example drawing containing it.
It is one of those anomalies that is not dwg resident, but just shows up sometimes, and others it will not be seen for days/weeks. Not always in the same dwgs. Seeing as Alan and I both use Civil3D, and very few others have reported this, I suspect it is something in that or Map which caused this graphics glitch.
Rob...
« Reply #16 on: September 12, 2016, 12:46:41 PM »
I've seen it before and it is persistent. Usually only noticed it when it is a distance away from the body of the drawing. Not using C3D.
CAD Tech
ChrisCarlson
« Reply #17 on: September 12, 2016, 01:00:20 PM »
Try disabling "High quality geometry" and / or "Smooth line display" under Graphics
Matt__W
  • I like my water diluted.
« Reply #18 on: September 12, 2016, 01:36:02 PM »
Have you tried rebooting? Or turning the monitor off/on?  :roll:
Autodesk Expert Elite
danallen
« Reply #19 on: September 12, 2016, 01:39:45 PM »
might need to completely reinstall windows....
« Reply #20 on: September 12, 2016, 01:40:35 PM »
Switch to a MAC
alanjt
  • Standby for witty remark...
« Reply #21 on: September 12, 2016, 02:01:31 PM »
I bet it's the system32 folder.
Dropbox
Matt__W
« Reply #22 on: September 12, 2016, 03:25:10 PM »
Yeah, not sure what you'll find though.
I have this thing at the corner of my drawing, very annoying.
tedg
« Reply #23 on: September 13, 2016, 10:51:07 AM »
John Carpenter's "The Thing".. good campy sci-fi movie.
showing my age but... I saw this when it came out at the drive in in 1982.
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
HasanCAD
« Reply #24 on: January 11, 2017, 03:28:13 AM »
I belive it is Text with Space only
