Author Topic: if #<%catch-all-apply-error%>  (Read 1354 times)
mailmaverick
« on: September 01, 2016, 06:57:46 AM »
I have a function which sometimes returns error.
For example (setq val (funcname argument1 argument 2))
Now sometimes val contains correct value. But sometimes, if there is an error within the function, it returns #<%catch-all-apply-error%>
(if (equal val #<%catch-all-apply-error%>) does not work.
How to check whether the function has returned correct value or error ?
Thanks.
kpblc
Re: if #<%catch-all-apply-error%>
« Reply #1 on: September 01, 2016, 07:13:59 AM »
Smth like this
(if (vl-catch-all-error-p (setq  err (vl-catch-all-apply (function (lambda () ... )))))
(princ (strcat "\Error : " (vl-catch-all-error-message err)))
Sorry for my English.
Grrr1337
« Reply #2 on: September 01, 2016, 04:46:49 PM »
Stick with kpblc's suggestion.
But I like alternatives, even if they seem useless... so:
(if (not (= 'VL-CATCH-ALL-APPLY-ERROR (type (setq err (vl-catch-all-apply (function (lambda () ... )))))))
< do stuff >
(apply ''((a b c)(a b c))
vevo.bg
« Reply #3 on: September 01, 2016, 05:21:54 PM »
Given a couple quick defuns ...
(defun _Try ( try_statement / try_catch try_result )
            (setq try_catch
                (vl-catch-all-apply
                    (function
                        (lambda ( )
                            (setq try_result (eval try_statement))
        (setq *try_errors* ;; global
            (cons
                (mapcar 'vl-prin1-to-string
                    (list
                        try_statement
                        (vl-catch-all-error-message try_catch)
    try_result
(defun c:ShowErrors ( )
    (foreach error *try_errors*
        (princ "\n")
        (princ error)
(defun c:ClearErrors ( )
    (setq *try_errors* nil)
Then ...
(_Try '(/ 1 2.0))    >> 0.5 (normal execution)
(_Try '(/ 1 0))      >> nil (error caught)
(_Try '(strlen nil)) >> nil (error caught)
(_Try '(* "2" 2))    >> nil (error caught)
ShowErrors (LIFO):
((* "2" 2) "bad argument type: numberp: \"2\"")
((STRLEN nil) "bad argument type: stringp nil")
((/ 1 0) "divide by zero")
Cheers.
mailmaverick
« Reply #4 on: September 03, 2016, 12:35:06 PM »
< do stuff >
Grrr1337's code did exactly what i wanted. Thanks to him and all others.
Grrr1337
« Reply #5 on: September 03, 2016, 04:21:20 PM »
Notice that
(not (= 'VL-CATCH-ALL-APPLY-ERROR (type ...is the same as
(not (vl-catch-all-error-p ...
vevo.bg
