Author Topic: Load C++ DLL from LISP  (Read 3715 times)
mailmaverick
« on: August 29, 2016, 11:55:57 AM »
How can I load and use C++ DLL by LISP ?
My C++ code is as under :-
int _stdcall useArray(double* dIn1, double* dIn2, double* dOut)
;; My code here
Source.def has been defined as :
LIBRARY "useArray"
EXPORTS
MyFunction = useArray
This function takes input values dIn1 and dIn2 as arrays and gives output in dOut as an array again.
Master_Shake
Re: Load C++ DLL from LISP
« Reply #1 on: August 29, 2016, 12:14:51 PM »
Wait, do you want to load a .DLL file from AutoLISP or load a .LSP from a .DLL?
mailmaverick
« Reply #2 on: August 29, 2016, 12:26:01 PM »
I have a .DLL file created in C++ which has a function named useArray.
I want to use this DLL in AutoLISP.
Master_Shake
« Reply #3 on: August 29, 2016, 12:30:28 PM »
Well if the .DLL is loaded, simply call it like you would any other command.
  1. (useArray)
  1. (setq var (useArray var1 var2))
If it is not loaded
  1. (command "_NETLOAD" "useArray.dll")
dgorsman
« Reply #4 on: August 29, 2016, 12:36:03 PM »
Ah, well that depends if the DLL actually defines a LISP function.  If it doesn't, then if it implements COM methods/properties those can be accessed through (vlax-invoke-method ...) and (vlax-get/set-property ...).  If neither of those then it cannot be used through LISP.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
mailmaverick
« Reply #5 on: August 29, 2016, 02:38:50 PM »
(command "_NETLOAD" "useArray.dll") returns NIL, it does not load.
DLL does not define a LISP function but is a pure C++ DLL.
I think  dgorsman's vlax-invoke-method can be used.
But how.
Master_Shake
« Reply #6 on: August 29, 2016, 03:34:53 PM »
In order to netload to work, the DLL needs to be in a folder read by AutoCAD.
dgorsman
« Reply #7 on: August 29, 2016, 04:45:13 PM »
But how.
Those require the DLL to have a COM interface.  If its "pure C++" with no COM interface then you still cannot call directly using LISP.  If you cannot add LISP functions to the DLL you would need to roll-your-own DLL wrapper to provide the appropriate LISP functions.
try {GreatPower;}
      {MasterBasics;}
  • (x-in)->[process]->(y-out)
« Reply #8 on: August 29, 2016, 04:54:33 PM »
But how.
dgorsman is correct, there is no way to load this dll unless it exposes a COM interface or it is created as an ObjectARX application that exposes a Lisp function interface. The NETLOAD command is used to load .Net assembly dll's, you can't load a native (C++) dll with NETLOAD.
If this was written by youself or you know the person perhaps you can ask them to write it in .Net, that is the easiest way forward IMO.
<added> actually, you would need to expose the .Net dll with a Lisp interface as well, to hook different runtime tecnnologies you need to provide some way for them to talk to each other and these interfaces are what make that possible.
"The E in Javascript stands for 'easy'." — Florin Pop tweet
mailmaverick
« Reply #9 on: August 30, 2016, 04:42:38 PM »
Thanks for your comments.
I want to use LISPLAB as given at https://common-lisp.net/project/lisplab/ in Autolisp / Visual LISP.
Can you help me on this.
« Last Edit: August 30, 2016, 05:31:33 PM by mailmaverick »
ur_naz
  • Made in Ukraine
« Reply #10 on: September 03, 2016, 06:00:25 PM »
« Reply #11 on: September 03, 2016, 07:15:06 PM »
that looks good ur_naz!
Will it handle the LISPLAB lib if it doesn't have a COM interface? I couldn't easily tell by looking at the code which by the way is pretty cool and heavy duty, I will be studying that for a while :)
« Last Edit: September 03, 2016, 07:19:13 PM by MickD »
baitang36
« Reply #12 on: September 22, 2022, 12:11:09 AM »
;; My code here
LIBRARY "useArray"
EXPORTS
Lisp can load dlls. A reserved function load-dll is required
This function autodesk is not exposed. The reserved function needs to be converted before it can be used. Look here http://bbs.mjtd.com/thread-185974-1-1.html?_dsign=674e21e0
domenicomaria
« Reply #13 on: September 22, 2022, 03:01:56 PM »
Lisp can load dlls.
Look here
I am studying lsp to directly call windows api.
After success, lsp will be as powerful
as other languages
​​and do whatever you want
This Is very interesting ...
xdcad
« Reply #14 on: November 22, 2023, 06:23:42 PM »
Lisp can load dlls.
Look here
as other languages
xdrx-load-dll
xdrx-unload-dll
[XDrx-Sub Forum]
https://www.theswamp.org/index.php?board=78.0
https://github.com/xdcad/XDrx-API
http://bbs.xdcad.net
