Author Topic: AutoCAD 2015 & .Net Framework 4.6.1  (Read 8995 times)
Andrey Bushman
Re: AutoCAD 2015 & .Net Framework 4.6.1
« Reply #15 on: August 24, 2016, 09:46:00 AM »
Hm... From here:
Quote from: Autodesk
As an optional step to get a complete clean removal of the .NET files, run the .NET Framework Cleanup Tool. Here is the download page:
.NET Framework Cleanup Tool User's Guide
But this tool doesn't remove .Net Framework... Look my screens. After computer restarting I see the same like 0.png. If I try to install .Net Framework 4.5 then I get the message that it (or its newer version) is already installed.
Andrey Bushman
« Reply #16 on: August 24, 2016, 09:53:09 AM »
In the log-file I see such strings:
Quote from: LOG-file
[08/24/16,15:28:23] Attempting to stop the service 'httpfilter'
[08/24/16,15:28:23] ***WARNING*** Failed to open the service 'httpfilter'
[08/24/16,15:28:23] Found entry msftpsvc, performing action now
[08/24/16,15:28:23] Attempting to stop the service 'msftpsvc'
[08/24/16,15:28:23] ***WARNING*** Failed to open the service 'msftpsvc'
[08/24/16,15:28:23] Found entry nntpsvc, performing action now
[08/24/16,15:28:23] Attempting to stop the service 'nntpsvc'
[08/24/16,15:28:23] ***WARNING*** Failed to open the service 'nntpsvc'
[08/24/16,15:28:23] Found entry smtpsvc, performing action now
[08/24/16,15:28:23] Attempting to stop the service 'smtpsvc'
[08/24/16,15:28:23] ***WARNING*** Failed to open the service 'smtpsvc'
[08/24/16,15:28:23] Found entry w3svc, performing action now
[08/24/16,15:28:23] Attempting to stop the service 'w3svc'
[08/24/16,15:28:25] Successfully stopped the service 'w3svc'
[08/24/16,15:28:25] Found entry iisadmin, performing action now
[08/24/16,15:28:25] Attempting to stop the service 'iisadmin'
[08/24/16,15:28:25] ***WARNING*** Failed to open the service 'iisadmin'
So, this tools dosn't work for me.
Andrey Bushman
« Reply #17 on: August 25, 2016, 08:36:02 AM »
This problem decision is here.
Andrey Bushman
« Reply #18 on: August 25, 2016, 08:38:34 AM »
I edited link.
