Author Topic: ActiveX Help for LISPin' folks ...  (Read 18140 times)
nivuahc
« Reply #15 on: May 15, 2005, 06:19:12 PM »
I'm reminded of those commercials for Guinness beer...
Quote from: Guinness Beer Guy
Brilliant!
nivuahc
« Reply #16 on: May 16, 2005, 08:20:46 AM »
Just tested it on Vanilla 2002 and it works perfectly!
Thanks again Michael!
Crank
« Reply #17 on: May 16, 2005, 09:33:09 AM »
Thanks Michael, this makes life a lot easier!
2 questions:
  • Can you add getkword to choose between AxPROPS and nAxPROPS?
  • If there is already a helpscreen in the background, is it possible then to use that window?[/list:u]
« Reply #18 on: May 16, 2005, 10:27:01 AM »
Quote from: Crank
My pleasure, hope it helps you along your journey. :)
Quote from: Crank
I'd rather not, but then again, maybe you're not the only one who wants this. Is it the naming that bugs you, like would you prefer AxPropsX for the nested version? Notwithstanding, there's nothing stopping you from calling (AxProps x) anyway you want via your own wrapper, including exactly as you described.
Quote from: Crank
I could, but <guessing> it would not immediately receive focus. Also, I thought folks might want to have independent windows for subsequent help screens.
You guys indicate what you want, I'll try to respond to the majority.
« Reply #19 on: May 16, 2005, 11:50:39 AM »
Please note that I found a bug in the program this morning. It crashes on PolyLines. The fix is easy, but I don't have the source code here, so I'll fix it up when I get home tonight.
Also, regarding Crank's request consider this quick one off:
(defun c:Propsx ( / mia getkey key lst )
        (   (and
                (setq mia (null AxProps))
                (null (findfile "axprops.fas"))
            (princ "Cannot find axprops.fas, aborting.")
        (   (and
                mia
                (eq 'failed (load "axprops.fas"))
            (princ "Cannot load axprops.fas, aborting.")
        (   (defun GetKey ( / result )
                (while
                    (null
                        (eq 2
                            (car
                                (setq result (grread))
                (cadr result)
            (setq lst
                (mapcar 'ascii
                   '("p" "P" "n" "N" "\r" " ")
            (if mia (princ "\n\n"))
            (princ
                (strcat
                    "Press [p] or [enter] to select a "
                    "primary entity, [n] for a nested one: "
            (while
                (null
                    (member
                        (setq key (GetKey))
                        lst
            (setq ename
                (car
                    (if (member key (mapcar 'ascii '("n" "N")))
                        (nentsel)
                        (entsel)
            (AxProps ename)
« Reply #20 on: May 16, 2005, 09:23:52 PM »
Bug squished, please download latest version.
AxProps.fas (use your logon name / password).
Altered presentation of data slightly, I'll let you find the change.
DEVITG
Re: ActiveX Help for LISPin' folks ...
« Reply #21 on: December 25, 2005, 09:19:56 AM »
Hi Michael , just one of the best gift on my chrismas tree.
« Reply #22 on: December 26, 2005, 01:55:12 AM »
Waaaaat the ... well, thanks DEVITG, right nice of you to say so ... thanks!
GDF
« Reply #23 on: December 26, 2005, 08:54:02 AM »
Thank you Michael. I like it as much as you ATOMS.vlx routine. I think the people at Autodesk would make use of this.
Gary
« Reply #24 on: December 26, 2005, 10:35:25 AM »
Thanks Gary! lol, it seems like a lifetime ago when I wrote atoms, I kinda forgot about it.
:lol:
Joe Burke
« Reply #25 on: December 30, 2005, 05:14:57 AM »
Very nice, Michael. Thank you.   :-)
A couple cosmetic questions. Could the window be resizable? Likewise, recall its last location and size?
On my two monitor setup the window always appears centered on the drawing window monitor, regardless of where it was when last closed. I'd prefer to have it on the other monitor so it doesn't obscure the drawing.
Forgive me if this is nit-picking.
77077
« Reply #26 on: June 05, 2015, 12:06:35 AM »
Thanks for sharing .
where is the Atoms.vlx ?
« Reply #27 on: June 05, 2015, 11:13:21 PM »
77077
« Reply #28 on: June 05, 2015, 11:24:53 PM »
