Author Topic: Empty drawing slow to open, purge, insert blocks  (Read 11403 times)
rkmcswain
Re: Empty drawing slow to open, purge, insert blocks
« Reply #30 on: August 10, 2016, 02:10:44 PM »
...and then opening the 11k drawing in C3D 2017 and immediately saving it, results in a 430k DWG file.
Matt__W
  • I like my water diluted.
« Reply #31 on: August 22, 2016, 04:23:15 PM »
Just wanted to post an update/resolution to our particular problem. Link to Autodesk Civil 3D forum
Autodesk Expert Elite
« Reply #32 on: August 22, 2016, 05:55:10 PM »
to quote you from the link
AeccNetwork.dbx files
where or how did you replace this file or files?
Was yours corrupted, or superseded by a service patch?
Matt__W
« Reply #33 on: August 22, 2016, 06:43:30 PM »
Simply had our IT geeks overwrite the existing files.
Not entirely sure.
