Author Topic: Empty drawing slow to open, purge, insert blocks  (Read 11401 times)
Re: Empty drawing slow to open, purge, insert blocks
« Reply #15 on: August 09, 2016, 11:10:23 AM »
There are a lot of blocks that cannot be purged. Why?
« Reply #16 on: August 09, 2016, 11:11:20 AM »
What about inserting a block? Does it take a while the first time you insert a block into that drawing?
Nope! :)
« Reply #17 on: August 09, 2016, 11:12:27 AM »
probably used by c3d styles...and thus not purgable
« Reply #18 on: August 09, 2016, 11:13:07 AM »
at the 16 second point I have now with it, I wouldn't consider that a problem
« Reply #19 on: August 09, 2016, 11:20:15 AM »
I just wblocked it all out to a new file...opens in 4+/- seconds
upon closing and reopening
I now see this at command line:
Command: ** Undefined shape 65
** Undefined shape 97
** Undefined shape 66
** Undefined shape 98
** Undefined shape 67
** Undefined shape 99
** Undefined shape 68
and the load time has creeped back up
Jeff H
« Reply #20 on: August 09, 2016, 11:30:33 AM »
If you want to clean all the stuff out just use
-EXPORTTOAUTOCAD command
« Reply #21 on: August 09, 2016, 11:36:56 AM »
So you have reached the same conclusion I did:
The file is NOT EMPTY at all.
Jeff H
« Reply #22 on: August 09, 2016, 11:44:13 AM »
When I saw attachment was 1504kB, I thought that was empty for a Civil 3D drawing.
I knew MEP drawing cleaned out was still about twice as big a vanilla  empty drawing.
« Reply #23 on: August 09, 2016, 11:49:23 AM »
Even after purging i can't get that.
« Reply #24 on: August 09, 2016, 11:56:24 AM »
That speeds it up! :)
« Reply #25 on: August 09, 2016, 12:26:15 PM »
Try my file posted above...
« Reply #26 on: August 09, 2016, 01:00:25 PM »
Opens right up. After a save though it takes much longer.
Matt__W
  • I like my water diluted.
« Reply #27 on: August 09, 2016, 01:37:26 PM »
If you're saving in Civil 3D, it's automatically adding some default C3D styles to the drawing.
Autodesk Expert Elite
« Reply #28 on: August 09, 2016, 03:21:02 PM »
But still, none of my other C3D files take that long to open.
rkmcswain
« Reply #29 on: August 10, 2016, 02:06:38 PM »
It opens in BricsCAD in less than 2 seconds.
Then I ran an AUDIT, Purged it, and exported to DWG (I'm presuming this is like an AutoCAD Wblock *) and the resulting file is 11k
(Doing the Audit + Purge and then simply saving in BricsCAD does not kill the file size. It's still ±1421k)
