Author Topic: Empty drawing slow to open, purge, insert blocks  (Read 11405 times)
Matt__W
  • I like my water diluted.
« on: August 08, 2016, 01:15:00 PM »
Rather than re-write everything, here's a link to my original post on the Autodesk Civil 3D forums. Trying to figure out why DWGs are only affected in Civil 3D. Slowness opening, inserting blocks from a network drive, purging.
This one is really bugging me. Any thoughts, suggestions, etc. are appreciated.
Autodesk Expert Elite
cadtag
Re: Empty drawing slow to open, purge, insert blocks
« Reply #1 on: August 08, 2016, 01:23:52 PM »
to be certain you're stating with a clean template, set FILEDIA to 0, then type .NEW, and at the template prompt enter a period (.)
same problems?  (oh, and remember to reset FILEDIA back to 1)
Matt__W
« Reply #2 on: August 08, 2016, 02:10:58 PM »
Yup. Same problems.
« Reply #3 on: August 08, 2016, 02:15:16 PM »
are you getting the updating old drawing message along with this general slowness?
Matt__W
« Reply #4 on: August 08, 2016, 02:48:34 PM »
Nope.
« Reply #5 on: August 08, 2016, 04:01:38 PM »
how slow is it for ME to open one of those empty files?
Matt__W
« Reply #6 on: August 09, 2016, 08:39:48 AM »
The attached drawing takes me 32 seconds to open. From the moment I click the OPEN button to the time I get the crosshairs.
rkmcswain
« Reply #7 on: August 09, 2016, 09:31:52 AM »
In my heavily customized 2014 environment, it takes ±45 seconds to open.
In a plain jane 2016 environment, it takes ±45 seconds to open.
In a moderately customized 2017 environment, it takes ±20 seconds to open.
Matt__W
« Reply #8 on: August 09, 2016, 10:05:49 AM »
Really? There's nothing in it! I don't get why it would take that long. Seems a bit much.
Side note... Still waiting to get access to ProcMon.  :|
Matt__W
« Reply #9 on: August 09, 2016, 10:08:32 AM »
It took a guy in our office using AutoCAD MEP 2015 +/- 3 seconds to open it. Windows 7, SSD, 32GB.
Jeff H
« Reply #10 on: August 09, 2016, 10:22:08 AM »
Could load autocad's mgdbg or if one specifically for Civil(Jeff M would know), and turn on printing events to command line to see if notice anything to help narrow it down.
« Reply #11 on: August 09, 2016, 10:46:06 AM »
53 seconds! Win7 C3D 2016. Weird.
« Reply #12 on: August 09, 2016, 11:00:05 AM »
I  got around 42 seconds with your posted drawing,
Then I purged and removed four &(*&%(^%*& named blocks and did a save as.
Now opens in around 16 seconds.
« Reply #13 on: August 09, 2016, 11:05:19 AM »
That is what i'm currently doing. Even running the PURGE command takes 40 seconds.
Matt__W
« Reply #14 on: August 09, 2016, 11:07:10 AM »
I'm glad to see you're experiencing what I'm dealing with over here. It just doesn't make any sense why everything is running so slow!
What about inserting a block? Does it take a while the first time you insert a block into that drawing?
