Author Topic: How to get List of all Files on a FTP Page  (Read 5073 times)
ChrisCarlson
Re: How to get List of all Files on a FTP Page
« Reply #15 on: August 16, 2016, 10:27:07 AM »
[1] site list
[1] 550 Permission denied.
PKENEWELL
« Reply #16 on: August 16, 2016, 01:54:05 PM »
OK - got this working. It's clunky and slow but it does what the OP wants. Change the variables for paths and ftp information to fit the server and directory needed. NOTE: for some reason, you cannot save the batch file in the same directory as the runftp.txt script or results. it starts an endless loop. I don't know why it would do that.
(Not much for Error checking in this - alter as you will)
(defun c:testFTP (/ bpth pth2 ftp ftpp usrn pswd fl wscript cmd exec res rtn)
   (setq bpth "c:\\users\\philk\\"
         pth2 "c:\\users\\philk\\documents\\"
         ftp "ftp.opera.com"
         ftpp "/pub/opera/win/1218/en/"
         usrn "anonymous"
         pswd "myemail@email.com"
   (setq fl (open (strcat bpth "FTP.BAT") "w"))
   (write-line "REM Set the working path" fl)
   (write-line (strcat "cd " pth2) fl)
   (write-line "" fl)
   (write-line "REM Write a Script to run the FTP commands" fl)
   (write-line (strcat "echo open " ftp "> runftp.txt") fl)
   (write-line (strcat "echo user " usrn " " pswd ">> runftp.txt") fl)
   (write-line (strcat "echo cd " ftpp ">> runftp.txt") fl)
   (write-line (strcat "echo dir -r " pth2 "ftpdir.txt>> runftp.txt") fl)
   (write-line "echo bye>> runftp.txt" fl)
   (write-line "" fl)
   (write-line "REM Launch FTP and pass it the script" fl)
   (write-line "ftp -n -s:runftp.txt" fl)
   (write-line "" fl)
   (write-line "REM Clean up." fl)
   (write-line "del runftp.txt" fl)
   (close fl)
   (if (setq wscript (vlax-create-object "WScript.Shell")
             cmd (findfile (strcat bpth "FTP.BAT"))
           (setq exec (vlax-invoke wscript 'Exec cmd))
           (while (and exec (= 0 (vlax-get-property exec 'Status)))
                  (princ (strcat "\rWaiting for Program \"" cmd "\"..."))
           (mapcar 'vlax-release-object (list exec wscript))
   (if (setq res (findfile (strcat pth2 "ftpdir.txt")))
         (setq fl (open res "r"))
         (while (setq ln (read-line fl))
            (princ (strcat "\n" ln))
            (setq rtn (reverse (cons ln (reverse rtn))))
         (close fl)
   (princ "\n\n")
   rtn
« Last Edit: August 16, 2016, 03:38:36 PM by PKENEWELL »
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
Andrea
« Reply #17 on: August 20, 2016, 03:10:05 PM »
did you tried to map a simple drive to the FTP site with windows..and then....read the file normaly ?
Keep smile...
PKENEWELL
« Reply #18 on: August 22, 2016, 01:16:17 PM »
Yes Interesting :idiot2: :-). I hadn't considered that since I haven't used FTP in ages. Seems like a sensible approach to me. The only drawback is depending on local drive mappings, which in a large user base can be difficult if all mappings are not forced to be the same. If a large company CAD base, the OP or his IT admin would also have to make a login script to establish all the drive mappings to a letter that (hopefully) isn't already mapped by someone. If the OP's CAD user base is relatively small though, it could be relatively easy to setup per user.
