Author Topic: partial cui loaded properties - double-click edit  (Read 3498 times)
alanjt
  • Standby for witty remark...
« on: August 04, 2016, 09:43:53 AM »
Is it possible to load a partial CUI that includes double-click edits and have them work, or do double-click edits have to be in the main cui?
Does anyone have a hierarchy breakdown of enterprise vs. main vs. partial cuis?
Dropbox
Re: partial cui loaded properties - double-click edit
« Reply #1 on: August 04, 2016, 11:35:00 AM »
Have you removed DBL_CLK EDIT from the main CUI, and added it to a partial that is loaded and tested it?
alanjt
« Reply #2 on: August 04, 2016, 11:45:28 AM »
There are some double-click edit features in the main cui, but the ones the partial cui would load are different. Is it a one-or-the-other kind of setup?
Dropbox
« Reply #3 on: August 04, 2016, 12:12:12 PM »
Its a top down hierarchy
when there are  numerous CUIX's loaded, the Double Click Actions (along with most other things in the cuix's) are given preference based on the load order of the cuix they are contained in.
alanjt
« Reply #4 on: August 04, 2016, 01:19:01 PM »
So, if there are 3 partial cuixs loaded, each with different double-click actions, only the first partial cuix will load its respective double-click actions and the other two will be ignored?
Dropbox
« Reply #5 on: August 04, 2016, 02:09:11 PM »
no they will activate in order top down..until it runs out of them  (that's the theory any way)
also they must be defined correctly or they wont work, so that might make it appear that lower in the tree cui/partial cui don't work
alanjt
« Reply #6 on: August 04, 2016, 02:15:59 PM »
Ugh, what a pain.
OK. I must have defined them incorrectly then.
So, by that understanding, as the enterprise, main, and partial cui files are loaded, as long as a feature isn't added for that one particular action (eg. double-click for a circle), then it will load the first one it finds. Correct?
Dropbox
« Reply #7 on: August 04, 2016, 02:23:18 PM »
Ugh, what a pain.
yes...it basically cascades downward
alanjt
« Reply #8 on: August 04, 2016, 02:30:53 PM »
I'm an idiot. I was adding acdb to the object name. Apparently you only have to put the object name itself.
I swear you used to have to put the dxf 100 name. Oh well. Thank you for your help, Michael.
Dropbox
BlackBox
« Reply #9 on: August 04, 2016, 11:42:33 PM »
Not sure what, if anything has changed since this:
https://www.theswamp.org/index.php?topic=39112.msg443213#msg443213
Cheers
alanjt
« Reply #10 on: August 09, 2016, 02:48:06 PM »
Cheers
Thank you.
I had come across a white paper long ago about this, but I couldn't find where I'd saved it or locate on the internet. This answers the remainder of my questions. *saving*
Sad part is, I'm in that thread.  :|
Dropbox
