Author Topic: Having an issue with unsatisfied constraints  (Read 2359 times)
Barry Clark
  • Mosquito
« on: July 15, 2016, 07:08:28 PM »
My old account was seemingly deleted. I guess my annual activity wasn't enough to avoid an inactive user cull. :)
Anyways, I just got my head wrapped around lookup tables. In the Family Types editor, all of the parameters are changing as I want them to. However, when I try to tie one of the properties for Actual OD (CapOD) to the diameter of the cylinder, I get an unsatisfied constraint warning (id 3093). For the life, of me, I can't figure what is going on.
It is a simple fitting: cap. I figured starting simply was the best way.
I am sure it is something simple that I am just missing.
Thanks!
Revit MEP 2016
Revit 2017
rvhwlc
Re: Having an issue with unsatisfied constraints
« Reply #1 on: July 18, 2016, 12:11:05 AM »
the dimension is not properly placed. try not ever constraining geometry, but the sketch. Delete the dimension, edit the extrusion and place a diameter dimension to the sketch itself.. .now you can associate the parameter to the dimension and it will work
Barry Clark
  • Mosquito
« Reply #2 on: July 18, 2016, 12:18:58 PM »
Thanks a ton for the response. I believe I follow. To be sure:
Make a circle as opposed to just making an extrusion based on a circle and generate a sweep based on that circle. Then dimension the circle but NOT the resulting sweep. Correct?
Revit MEP 2016
Revit 2017
rvhwlc
« Reply #3 on: July 18, 2016, 02:31:14 PM »
no this is too much work. simply click the extrusion and click edit... the sketch that drives the extrusion, this is what you apply a dimension to.
Barry Clark
  • Mosquito
« Reply #4 on: July 19, 2016, 11:14:27 AM »
I believe I follow. I will give that a shot! Thanks!
Revit MEP 2016
Revit 2017
rvhwlc
« Reply #5 on: July 19, 2016, 03:12:17 PM »
if you follow, it will work. i tested with your file to make sure..
Barry Clark
  • Mosquito
« Reply #6 on: July 19, 2016, 05:33:12 PM »
I did and it did. Thanks a ton. That has been driving me nuts!
Revit MEP 2016
Revit 2017
Matt__W
  • I like my water diluted.
« Reply #7 on: July 20, 2016, 07:08:16 AM »
Always constrain reference planes and sketches and let THAT drive how the the geometry and model flexes.
Autodesk Expert Elite
Barry Clark
  • Mosquito
« Reply #8 on: July 20, 2016, 08:44:24 PM »
Thanks much! That's what I have going on with a more advanced part I am building now. :)
I do prefer working with reference planes. :D
Revit MEP 2016
Revit 2017
rvhwlc
« Reply #9 on: July 20, 2016, 11:49:33 PM »
reference planes is a requirement not a preference mayhem is right always use planes
Barry Clark
  • Mosquito
« Reply #10 on: July 21, 2016, 04:50:06 PM »
Indeed. I wasn't being very clear. Was meaning to say that I rather enjoy using them.
Revit MEP 2016
Revit 2017
