Is there a way I can run a lisp without needing to type in a command to execute it? More like, drag and drop in AutoCAD and it runs?
As a CAD Admin, I have needed this approach as well. Here is what I do:
You simply need to only add the defined command after the closing parenthesis as shown below.
Make sure that the command is enclosed in its own parentheses)
~Greg
Edit: Make sure that the 'C:' is included as the prefix to the defun.
Thanks Kdub
