Author Topic: Run a lisp without "C:Command"?  (Read 4776 times)
kdub
  • Mesozoic keyThumper
  • SuperMod
Re: Run a lisp without "C:Command"?
« Reply #15 on: July 20, 2016, 12:03:12 AM »
Hi Trogg
The final line would need to be  (C:CPR), surely ?
Called Kerry in my other life
I live at UTC + 13.00
some people complain about loading the dishwasher
trogg
« Reply #16 on: July 20, 2016, 03:04:24 PM »
Hi Trogg
I'm sorry, I should have made that more clear.
Don't remove the defined command at the top of the lisp. Leave that alone.
The only thing that I change in the routine is adding the command wrapped in parentheses at the end of the routine.
Updated in 2023...
I totally missed kerry's point with my response. Yes. The C: is included before the command as Kerry pointed out.
I have updated the image to be correct (after all these years...)
~Greg
« Last Edit: March 10, 2023, 12:02:32 PM by trogg »
ahsattarian
« Reply #17 on: March 10, 2023, 09:29:54 AM »
If you save the following code as runscript.lsp and you drag and drop this file from the explorer into the AutoCAD window the expression will evaluate.
  1. (if (findfile "C:/path/yourscript.scr")
  2.   (command "_script" "C:/path/yourscript.scr")
  3. )
I've Checked other file names and can say that every file name acts the same as     runscript   .
Every lisp file acts when drag and droped in AutoCAD.
