Author Topic: AutoCAD table from excel datalink  (Read 3091 times)
xenspidey
  • Mosquito
« on: July 08, 2016, 02:41:46 PM »
I'm working on switching over from OLE to native tables from Excel datalinks. I want to preserve excel formatting (merged cells, column width, etc) but I want to override the font used. So far the only way I can see of doing it is to uncheck the option to use excel formatting. But if I do that the tables took dreadful! Has anyone every wanted to do the same or have any thoughts on things I could try?
Bryco
Re: AutoCAD table from excel datalink
« Reply #1 on: July 09, 2016, 06:17:19 PM »
does your table template not let you pick the font?
xenspidey
  • Mosquito
« Reply #2 on: July 11, 2016, 11:34:06 AM »
Yes, but when I have the option of "Use Excel formatting" checked it overwrites the font. I need to be able to keep it checked but override the font somehow. The excel sheet has a lot of merged cells and column widths that i need to keep.
« Reply #3 on: July 11, 2016, 11:48:49 AM »
perhaps select a font that each application shares...as an example SIMPLEX is common to both applications
Jeff H
« Reply #4 on: July 11, 2016, 01:16:54 PM »
Seems like it goes to crap if excel has merged cells.
xenspidey
  • Mosquito
« Reply #5 on: July 11, 2016, 02:03:50 PM »
Unfortunately fonts are dictated and out of my control... TTF's have always caused us issues so that wouldn't be an option anyways.
xenspidey
  • Mosquito
« Reply #6 on: July 11, 2016, 02:04:53 PM »
They don't "have" to be merged, I can get away with just centering across selection... again though that still requires that the AutoCAD table matches Excel styling.
