Author Topic: Using Object Data to label linework  (Read 4879 times)
cyclops
« on: July 05, 2016, 12:05:32 PM »
I am working with drawings with objectdata attached to the linework from a shape file, what i need is to automate the process of labeling the linework, by extracting multiple fields/data from the odjectdata, then labeling the linework with a multi-leader.
Does anyone have a lisp routine or other way to automate the process?
I need the process to be point and shoot, i am working with interns, enough said.
Cy
It's 'O'Neill', with three L's!!!! (Jack O'Neill)
ChrisCarlson
Re: Using Object Data to label linework
« Reply #1 on: July 05, 2016, 12:21:12 PM »
There are numerous companies which you can contract to make this.
One such is
http://lee-mac.com/contact.html
cyclops
« Reply #2 on: July 05, 2016, 12:54:22 PM »
Chris,
I am working to that end but admin is requesting an example, prior to allocating monies.
I need to know if what I have asked is possible.
Thanks,
Cy
« Reply #3 on: July 05, 2016, 12:55:52 PM »
Cy
Use MAP  it has features just for this sort of thing.  They are called Map Annotation Templates.
Demo version of MAP = FREE
cyclops
« Reply #4 on: July 05, 2016, 01:04:30 PM »
mjfarrell,
I have worked a little with map annotation templates, to label parcels but that was an en mass method, is there a way to selectively to label singular objects as needed?
Thanks,
Cy
alanjt
  • Standby for witty remark...
« Reply #5 on: July 05, 2016, 01:16:50 PM »
It's possible.
What discipline/version of cad are you using?
I extract object data from imported SHP data quite often.
Dropbox
cyclops
« Reply #6 on: July 05, 2016, 01:25:03 PM »
alanjt,
I am using civil3d 2012-2016. I have also, but on the fly labeling seems more complex than en mass labeling.
Thanks,
Cy
alanjt
« Reply #7 on: July 05, 2016, 01:33:07 PM »
alanjt,
Thanks,
Cy
Cool.
I assume you have a specific set of fields you want to extract for labeling. All one needs is a list, and it can easily be extracted.
Dropbox
cyclops
« Reply #8 on: July 05, 2016, 03:40:03 PM »
alanjt,
Yes, i am pulling 8 fields from a set of 30+.
The fields may change, i can make a different anno label for different needs?
Thanks,
Cy
« Reply #9 on: July 06, 2016, 08:16:00 AM »
alanjt,
Thanks,
Cy
Just create your annotation templates and apply as needed
Yes it works well en mass via a query operation,
however it also can be applied selectively
further annotation labels can later be converted to text if that is desired.
BlackBox
« Reply #10 on: July 06, 2016, 11:18:57 PM »
You can also start by running manual MAPQUERY, to demonstrate the time needed to manually extract/label... Then leverage the seldom documented ADE_* LispFunctions to accomplish same in less time.
I used to do this back when we worked with Land Desktop; I'll see if I can find some code snippets.
Cheers
alanjt
« Reply #11 on: July 07, 2016, 08:40:56 AM »
(defun _getObjectData (ename / tables ass lst)
  (foreach table (setq tables (ade_odgettables ename))
    (foreach x (cdr (assoc "Columns" (ade_odtabledefn table)))
      (if (not (member (setq ass (cdr (assoc "ColName" x))) lst))
        (setq lst (cons ass lst))
  (mapcar (function (lambda (x) (cons x (ade_odgetfield ename tables x 0))))
          (vl-sort lst '<)
Dropbox
BlackBox
« Reply #12 on: July 07, 2016, 09:41:26 AM »
Once I'm done extracting the Object Data I need, I usually get rid of it to keep the drawing size as small as possible:
  1. (defun c:ODD () (c:ObjectDataDelete))
  2. (defun c:ObjectDataDelete (/ odTableName i n)
  3.   (princ "\rOBJECTDATADELETE ")
  4.   (if (and (setq odTables (ade_odtablelist))
  5.            (setq i (length odTables))
  6.            (setq n 0)
  7.            (princ "\nWorking, please wait... ")
  8.            (princ)
  9.       )
  10.     (progn
  11.       (foreach odTableName (ade_odtablelist)
  12.         (ade_oddeletetab odTableName)
  13.         (setq n (1+ n))
  14.       )
  15.       (princ "Done. ")
  16.       (prompt
  17.         (strcat "\nRemoved "
  18.                 (itoa n)
  19.                 " of "
  20.                 (itoa i)
  21.                 " object data table"
  22.                 (if (= 1 i)
  23.                   ". "
  24.                   "s. "
  25.                 )
  26.         )
  27.       )
  28.     )
  29.     (prompt "\n** No object data tables found ** ")
  30.   )
  31.   (princ)
  32. )
  33.
  34. ;; if not being loaded into map-enabled application
  35. (if (not ade_odtablelist)
  36.
  37.   ;; disabled these functions
  38.   (setq c:ODD (setq c:ObjectDataDelete nil))
  39. )
  40.
  41.
« Reply #13 on: July 07, 2016, 10:14:36 AM »
This seems counter productive to me.  I think of all the time wasted putting object data onto the objects, only to have it deleted?
What happens when and or if that object data is ever needed again?
BlackBox
« Reply #14 on: July 07, 2016, 10:46:08 AM »
Then I just go back to the 'source' drawing where I've already imported the County's GIS/Shapefile data with Object Data, and cull what I need, of course (i.e., project length changes, etc.)... Otherwise, I can simply run MAPIMPORT as needed (i.e., newer Shapefile is available, etc.)... That's only happened to me on 3 projects in the past 10 years, FWIW.
Cheers
