I used ODBX to change the attribute values in a title block inside some drawings.
When opening the drawings the title block attribs, that have a 'center' justification, appear have a 'left justification'.
Moving the title block (Move command) the attribs are regenerated and assumes the correct justification and position.
Someone found a solution to this problem?
I have tryed vl-regen, vl-update, vl-move (applied to the block) and also vl-put-alignment with the correct value... but nothing is appened.
