Author Topic: Need help with change attributes location in block  (Read 3758 times)
ziele_o2k
« on: June 14, 2016, 06:09:02 PM »
I have block with attributes. Based on location and rotation of main attribute I want to change location of the other atts.
To this moment I was working with block/attributes with rotation = 0. I was using some BoudingBox lips routines in UCS or WCS.
But now I don't know how to do.
I was thinking that maybe I should set UCS for every block I'm processing and get bounding box in UCS, but I don't know how to do this in lisp routine (without command "_UCS" which is slow).
To visualize problem, please see attached file.
Also I was thinking about trying to modify Lee Mac MinimumBoudingBox routine, but after my modifications it don't work for atts.
for every advice I will be grateful.
roy_043
  • BricsCAD 18
ziele_o2k
Re: Need help with change attributes location in block
« Reply #2 on: June 15, 2016, 06:20:16 AM »
This problem was also posted here:
http://www.cadtutor.net/forum/showthread.php?97195-Lisp-Minimum-bounding-box-for-rotated-attribute-block
I know, that was my post, here is solution,
;;ziele_o2k
;;v20160615-1216
(defun c:final ( / *error* ss in blkent attentlst Att-0 Att-1 Att-2 box os)
  (defun *error* (msg / so)
      ((not msg))
      ((member msg '("Function cancelled" "quit / exit abort")))
        (princ (strcat "\n  <!>  Error: " msg "  <!> "))
        (cond (T (vl-bt)))
  (if(setq ss (ssget '((0 . "INSERT") (2 . "GT-SP-TYP2") (66 . 1))))
      (repeat (setq in (sslength ss))
        (setq blkent (ssname ss (setq in (1- in))))
        (setq attentlst (cd:BLK_GetAttEntity blkent))
        (foreach %1 attentlst
            (lambda (%2)
                ((eq (cdr (assoc 2 (entget %2))) "NUMBER") (setq Att-0 (entget %2)))
                ((eq (cdr (assoc 2 (entget %2))) "SEPARATOR") (setq Att-1 (entget %2)))
                ((eq (cdr (assoc 2 (entget %2))) "LEVEL") (setq Att-2 (entget %2)))
            %1
        (if (and Att-0 Att-1 Att-2)
            (setq box (textbox Att-0))
            (setq os (/ (cdr (assoc 40 Att-1)) 8))
            (setq
              Att-1
              (subst
                (cons
                  10
                  (polar
                    (cdr (assoc 10 Att-0))
                    (cdr (assoc 50 Att-0))
                    (+ (caadr box) os)
                (assoc 10 Att-1)
                Att-1
              Att-1 (subst (assoc 50 Att-0)(assoc 50 Att-1)Att-1)
            (entmod Att-1)
            (setq box (textbox Att-1))
            (setq
              Att-2
              (subst
                (cons  10
                  (polar
                    (cdr (assoc 10 Att-1))
                    (cdr (assoc 50 Att-1))
                    (+ (caadr box) os)
                (assoc 10 Att-2)
                Att-2
              Att-2 (subst (assoc 50 Att-1)(assoc 50 Att-2)Att-2)
            (entmod Att-2)
            (entupd blkent)
          (princ "\nNo atts.")
There is still problem when we have spaces in begining or end of attribute string. Textbox function ignores that spaces.
But this problem is my future problem.
« Reply #3 on: June 15, 2016, 10:03:05 AM »
Does not move attributes, but gives similar end results ( minus the difference in text height ).
  1. (defun c:foo (/ _getatt r o n ss)
  2.   (defun _getatt (blk tag)
  3.     (car (vl-remove-if-not '(lambda (att) (= (strcase tag) (strcase (vla-get-tagstring att))))
  4.             (vlax-invoke blk 'getattributes)
  5.     )
  6.     )
  7.   )
  8.   (if (setq ss (ssget ":L" '((0 . "insert") (2 . "GT-SP-TYP2") (66 . 1))))
  9.     (foreach blk (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
  10.       (if (and (setq r (_getatt blk "number"))
  11.           (setq o (_getatt blk "separator"))
  12.           (setq n (_getatt blk "level"))
  13.      )
  14.        r
  15.           )
  16.           (vla-put-textstring o "")
  17.           (vla-put-textstring n "")
  18.    )
  19.       )
  20.     )
  21.   )
  22.   (princ)
  23. )
& here's one that moves the attributes:
  1. (defun c:foo (/ _clean _d _getatt r o n ss p a d)
  5.     )
  6.     )
  7.   )
  8.   (defun _d (e / r)
  9.     (if   (setq r (textbox (entget e)))
  10.       (caadr r)
  11.     )
  12.   )
  13.   (defun _clean (str) (vl-string-left-trim " " (vl-string-right-trim " " str)))
  14.   (if (setq ss (ssget ":L" '((0 . "insert") (2 . "GT-SP-TYP2") (66 . 1))))
  15.     (foreach blk (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
  16.       (if (and (setq r (_getatt blk "number"))
  17.           (setq o (_getatt blk "separator"))
  18.           (setq n (_getatt blk "level"))
  19.      )
  20.           (vla-put-textstring o (_clean (vla-get-textstring o)))
  21.           (vla-put-textstring n (_clean (vla-get-textstring n)))
  22.           (vlax-invoke o
  23.              'move
  24.              (vlax-get o 'insertionpoint)
  25.              (polar (setq p (vlax-get r 'insertionpoint))
  26.                (setq a (vla-get-rotation r))
  27.                (setq d (_d (vlax-vla-object->ename r)))
  28.              )
  29.           )
  30.           (vla-put-rotation o a)
  31.           (vlax-invoke n
  32.              'move
  33.              (vlax-get n 'insertionpoint)
  34.              (polar p a (+ d (_d (vlax-vla-object->ename o))))
  35.           )
  36.           (vla-put-rotation n a)
  37.    )
  38.       )
  39.     )
  40.   )
  41.   (princ)
  42. )
« Last Edit: June 15, 2016, 11:10:08 AM by ronjonp »
ziele_o2k
« Reply #4 on: June 15, 2016, 11:59:08 AM »
Here is mine but without cleaning spaces
  1. ;;ziele_o2k
  2. ;;v20160615-1802
  3. (defun c:final ( / *error* ss in blkent attentlst Att-0 Att-1 Att-2 box os)
  4.   (defun *error* (msg / so)
  5.     (cond
  6.       ((not msg))
  7.       ((member msg '("Function cancelled" "quit / exit abort")))
  8.       (
  9.         (princ (strcat "\n  <!>  Error: " msg "  <!> "))
  10.         (cond (T (vl-bt)))
  11.       )
  12.     )
  13.     (princ)
  14.   )
  15.   (if(setq ss (ssget '((0 . "INSERT") (2 . "GT-SP-TYP2") (66 . 1))))
  16.     (progn
  17.       (repeat (setq in (sslength ss))
  18.         (setq blkent (ssname ss (setq in (1- in))))
  19.         (setq attentlst (cd:BLK_GetAttEntity blkent))
  20.         (foreach %1 attentlst
  21.           (
  22.             (lambda (%2)
  23.               (cond
  24.                 ((eq (cdr (assoc 2 (entget %2))) "NUMBER") (setq Att-0 (entget %2)))
  25.                 ((eq (cdr (assoc 2 (entget %2))) "SEPARATOR") (setq Att-1 (entget %2)))
  26.                 ((eq (cdr (assoc 2 (entget %2))) "LEVEL") (setq Att-2 (entget %2)))
  27.               )
  28.             )
  29.             %1
  30.           )
  31.         )
  32.         (if (and Att-0 Att-1 Att-2)
  33.           (progn
  34.             (setq box (PZ:TextBox Att-0))
  35.             (setq os (/ (cdr (assoc 40 Att-1)) 8))
  36.             (setq
  37.               Att-1
  38.               (subst
  39.                 (cons
  40.                   10
  41.                   (polar
  42.                     (cdr (assoc 10 Att-0))
  43.                     (cdr (assoc 50 Att-0))
  44.                     (+ (caadr box) os)
  45.                   )
  46.                 )
  47.                 (assoc 10 Att-1)
  48.                 Att-1
  49.               )
  50.               Att-1 (subst (assoc 50 Att-0)(assoc 50 Att-1)Att-1)
  51.             )
  52.             (entmod Att-1)
  53.             (setq box (PZ:TextBox Att-1))
  54.             (setq
  55.               Att-2
  56.               (subst
  57.                 (cons  10
  58.                   (polar
  59.                     (cdr (assoc 10 Att-1))
  60.                     (cdr (assoc 50 Att-1))
  61.                     (+ (caadr box) os)
  62.                   )
  63.                 )
  64.                 (assoc 10 Att-2)
  65.                 Att-2
  66.               )
  67.               Att-2 (subst (assoc 50 Att-1)(assoc 50 Att-2)Att-2)
  68.             )
  69.             (entmod Att-2)
  70.             (entupd blkent)
  71.           )
  72.           (princ "\nNo atts.")
  73.         )
  74.       )
  75.     )
  76.   )
  77.   (princ)
  78. )
  79.
  80. ;;ziele_o2k
  81. ;;20160615-1622
  82. ;;elist - An entity definition list defining a text object, in the format returned by entget.
  83. ;     (textbox (entget (car (entsel))))
  84. ;     (PZ:TextBox (entget (car (entsel))))
  85. (defun PZ:TextBox ( elist / str in SpaceCount SpaceLength)
  86.   (setq
  87.     str (cdr (assoc 1 elist))
  88.     in 0
  89.     SpaceCount 0
  90.   )
  91.   ;Count Spaces at begining of string
  92.   (while (eq (nth in (vl-string->list str)) 32)
  93.     (setq
  94.       SpaceCount (1+ SpaceCount)
  95.       in (1+ in)
  96.     )
  97.   )
  98.   ;Count Spaces at end of string
  99.   (setq in 0)
  100.   (while (eq (nth in (reverse (vl-string->list str))) 32)
  101.     (setq
  102.       SpaceCount (1+ SpaceCount)
  103.       in (1+ in)
  104.     )
  105.   )
  106.   ;Calculate space length
  107.   (setq
  108.     SpaceLength
  109.     (-
  110.       ;String with space
  111.       (caadr
  112.         (textbox
  113.           (entmod
  114.             (subst
  115.                 (cons 1 "A A")
  116.                 (assoc 1 elist)
  117.                 elist
  118.             )
  119.           )
  120.         )
  121.       )
  122.       ;String without space
  123.       (caadr
  124.         (textbox
  125.           (entmod
  126.             (subst
  127.                 (cons 1 "AA")
  128.                 (assoc 1 elist)
  129.                 elist
  130.             )
  131.           )
  132.         )
  133.       )
  134.     )
  135.   )
  136.   ;Restore string value to default
  137.   (entmod
  138.    (subst
  139.       (cons 1 str)
  140.       (assoc 1 elist)
  141.       elist
  142.     )
  143.   )
  144.   ;return list with textbox coordinates
  145.   (list
  146.     (car (textbox elist))
  147.     (list
  148.       (+ (caadr (textbox elist)) (* SpaceLength SpaceCount))
  149.       (cadr (cadr (textbox elist)))
  150.       (caddr (cadr (textbox elist)))
  151.     )
  152.   )
  153. )
« Reply #5 on: June 15, 2016, 01:14:46 PM »
You need to include the function CD:BLK_GETATTENTITY.
Nice to see someone coding & not asking for a handout .. Welcome to TheSwamp.  :)
roy_043
  • BricsCAD 18
« Reply #6 on: June 15, 2016, 04:36:41 PM »
@ ziele-o2k:
As I tried to explain in your thread on the other forum, there is no need to actually change an entity for the (textbox) function. You can completely remove entmod (3x) from your PZ:TextBox function.
(textbox (entmod (subst ...)))Can become:
(textbox (subst ...))
ziele_o2k
« Reply #7 on: June 16, 2016, 05:12:54 AM »
@ ziele-o2k:
New version of textbox.
  1. ; =========================================================================================== ;
  2. ;  DATA  [LIST] - An entity definition list defining a text object,                           ;
  3. ;                 in the format returned by entget                                            ;
  4. ;  Mode [T/nil] - nil = standard textbox function procedure                                   ;
  5. ;                       (ignore spaces at start and end of string)                            ;
  6. ;                 T   = extended textbox function                                             ;
  7. ;                       (do not ignore spaces at start and end of string)                     ;
  8. ; =========================================================================================== ;
  9. (defun TextBoxExt (Data Mode / _SpaceStr _SpacesI _SpaceLen s i e r)
  10.   (setq s (cdr (assoc 1 Data)) r (textbox Data))
  11.   (defun _SpaceStr (s / l)
  12.     (setq l (vl-string->list s))(or (= 32 (car l))(= 32 (last l)))
  13.   )
  14.   (defun _SpacesI (s / l)
  15.     (setq l (vl-string->list s))
  16.     (-
  17.       (length l)
  18.       (length (vl-string->list (vl-string-left-trim " " (vl-string-right-trim " " s))))
  19.     )
  20.   )
  21.   (defun _SpaceLen (d)
  22.     (-
  23.       (caadr (textbox (subst (cons 1 "A A")(assoc 1 d) d)))
  24.       (caadr (textbox (subst (cons 1 "AA")(assoc 1 d) d)))
  25.     )
  26.   )
  27.   (if Mode
  28.     (if
  29.       (_SpaceStr s)
  30.       (progn
  31.         (setq i (_SpacesI s) e (_SpaceLen Data))
  32.         (list
  33.           (car r)
  34.           (list
  35.             (+ (caadr r) (* e i))
  36.             (cadr (cadr r))
  37.             (caddr (cadr r))
  38.           )
  39.         )
  40.       )
  41.       r
  42.     )
  43.     r
  44.   )
  45. )
roy_043
  • BricsCAD 18
« Reply #8 on: June 16, 2016, 05:34:55 AM »
Great! Much better!
The post you have linked to in your other thread suggests that only trailing spaces are an issue. Your code also looks at leading spaces. I can't test this myself as the (textbox) function in BricsCAD measures all characters (which makes more sense IMO).
Three functions that may be useful:
(strlen "abc")
(vl-string-trim " " "  A  ")
(wcmatch " abc " " *,* ")
EDIT: Spelling.
« Last Edit: June 16, 2016, 07:56:49 AM by roy_043 »
ziele_o2k
« Reply #9 on: June 16, 2016, 07:36:49 AM »
Three functions that may be usefull:
(strlen "abc")
Next version :)
  9. (defun TextBoxExt (Data Mode / _SpacesI _SpaceLen s i e r)
  11.   (defun _SpacesI (s / l)
  12.     (-
  13.       (strlen s)
  14.       (strlen (vl-string-trim " " s))
  15.     )
  16.   )
  17.   (defun _SpaceLen (d)
  18.     (-
  19.       (caadr (textbox (subst (cons 1 "A A")(assoc 1 d) d)))
  20.       (caadr (textbox (subst (cons 1 "AA")(assoc 1 d) d)))
  21.     )
  22.   )
  23.   (if Mode
  24.     (if
  25.       (wcmatch s " *,* ")
  26.       (progn
  27.         (setq i (_SpacesI s) e (_SpaceLen Data))
  28.         (list
  29.           (car r)
  30.           (list
  31.             (+ (caadr r) (* e i))
  32.             (cadr (cadr r))
  33.             (caddr (cadr r))
  34.           )
  35.         )
  36.       )
  37.       r
  38.     )
  39.     r
  40.   )
  41. )
roy_043
  • BricsCAD 18
« Reply #10 on: June 16, 2016, 07:59:33 AM »
Nice work ziele-o2k. 8-)
« Reply #11 on: June 16, 2016, 09:33:57 AM »
Good coding ziele-o2k  :-)
Here is my version to offer an alternative approach:
  1. (defun textboxext ( enx flg )
  2.     (if (and flg (wcmatch (cdr (assoc 1 enx)) " *,* "))
  3.         (   (lambda ( a b ) (list (car a) (cons (- (caadr a) (caadr b)) (cdadr a))))
  4.             (textboxs enx (strcat "-" (cdr (assoc 1 enx)) "-"))
  5.             (textboxs enx "--")
  6.         )
  7.         (textbox enx)
  8.     )
  9. )
  10. (defun textboxs ( enx str )
  11.     (textbox (subst (cons 1 str) (assoc 1 enx) enx))
  12. )
