Author Topic: help help help  (Read 4943 times)
samideqlqpart
help help help
« on: June 13, 2016, 02:35:22 PM »
...There is no editor available for....... my file.vb https://www.theswamp.org/Smileys/black/cry.gif
and my when i open it with notepad , i found no code!!!
how to retrieve one year of hard works
thank u
ChrisCarlson
Re: help help help
« Reply #1 on: June 13, 2016, 02:57:33 PM »
Can't really help if you already tried to open it with NotePad.
Does it have a file size?
Can you upload it?
samideqlqpart
Re: help help help
« Reply #2 on: June 14, 2016, 12:45:50 PM »
hi
yes its indicates 476Ko
and when i opened it with notepad the cursor is at the begin and the page is blank!
as i know , every times i make ctrl+shift+S i save all things, as well as my program progress
that mean, an archive is created, but where is it!? and how to access?
ChrisCarlson
Re: help help help
« Reply #3 on: June 14, 2016, 12:59:36 PM »
Sounds like the file is blank either was corrupted or someone deleted everything.
samideqlqpart
Re: help help help
« Reply #4 on: June 14, 2016, 02:22:07 PM »
ok
but how to access my precedent saved files
ChrisCarlson
Re: help help help
« Reply #5 on: June 14, 2016, 02:42:35 PM »
I literally have no idea how your computer is setup. Not all text editors save a backup of each save. Are you using Notepad or Notepad++?
If notepad++ i'd check here
%AppData%/Notepad++/backup
Jeff H
Re: help help help
« Reply #6 on: June 14, 2016, 04:18:47 PM »
Maybe try right-clicking->properties->Previous version(tab)
samideqlqpart
Re: help help help
« Reply #7 on: June 15, 2016, 07:29:08 AM »
hi
i  have just notepad
and i've used it just for seeing my file.vb
in the properties i can't see the Previous version tab
my question now
is how you proceed to return to a precedent version of your saved file?
ChrisCarlson
Re: help help help
« Reply #8 on: June 15, 2016, 08:10:57 AM »
If you literally only use notepad.exe and have not setup previous versions within Windows, there is no way to recover a previous version.
Keith Brown
Re: help help help
« Reply #9 on: June 15, 2016, 08:33:31 AM »
It certainly does not do anything to help you now but you should read and follow the advice in this article.
http://stackoverflow.com/questions/1408450/why-should-i-use-version-control
samideqlqpart
Re: help help help
« Reply #10 on: June 15, 2016, 09:55:57 AM »
is it possible to get my file with GIT ?
otherwise conversely
from my dll ?
dgorsman
Re: help help help
« Reply #11 on: June 15, 2016, 10:16:46 AM »
Ah, no - I think you are missing something.  That's about establishing back-ups in general, and how version control helps with that.  You should *always* back up your work to somewhere else so if something like this happens you don't lose everything.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
ChrisCarlson
Re: help help help
« Reply #12 on: June 15, 2016, 10:17:36 AM »
Did you upload it to a repository, either locally or remote? If not, no.
You can go from DLL to source but the results are iffy at times.
samideqlqpart
Re: help help help
« Reply #13 on: June 15, 2016, 11:29:18 AM »
with decompilator or what to use in this case
thank
ChrisCarlson
Re: help help help
« Reply #14 on: June 15, 2016, 12:13:11 PM »
I'm not liking where this topic is going, starting to seem like you have someone else's DLL and you want the source to it. Suggest you google around
