Author Topic: Objects not plotting from PDF  (Read 5405 times)
Jeff H
Re: Objects not plotting from PDF
« Reply #15 on: May 26, 2016, 01:15:06 PM »
You might check PLOTTRANSPARENCYOVERRIDE.
Not sure if this helps but remeber looking at this when trying to figure it out here
http://kipamerica.blogspot.com/2011/08/pdf-quicktips-for-kip-systems.html
rkmcswain
« Reply #16 on: May 26, 2016, 01:25:14 PM »
Quote from: Jeff H
Nice technical article. Thanks for sharing.
Peter2
« Reply #17 on: May 26, 2016, 01:26:57 PM »
...but scaled down to 11x17, and it also printed fine...
(Not helpful for the issue, but this reminds me of the behaviour in Acad 14, where sometimes TTF where printed outlined. You have to scale the textstyle to 0.99 - this cause an internal regeneration and a correct printing.)
As said above if you can share the file other users with other soft- and hardware can test ...
Peter
BricsCAD V23
Crank
« Reply #18 on: June 11, 2016, 08:27:05 AM »
Could the plotter be running out of memory?
+1
Try a pdf with less dpi.
