Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Spltting Dimensions
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: Spltting Dimensions (Read 4343 times)
ahsattarian
Newt
Re: Spltting Dimensions
Reply #15 on:
November 07, 2023, 07:12:27 AM »
Have a look at this :
Code - Auto/Visual Lisp:
[Select]
defun
c:a
setq
fuzzy
0.01
defun
sub1
sj
setq
enj
entget
sj '
setq
po1
cdr
assoc
10
enj
setq
po2
cdr
assoc
11
enj
setq
po3
cdr
assoc
13
enj
setq
po4
cdr
assoc
14
enj
defun
sub2
cond
s1
entdel
s1
setq
s1
nil
entmod
en
sub1 s
defun
myortho
poj angj ptj
polar
poj angj
distance
poj ptj
cos
angle
poj ptj
angj
setq
s
car
entsel
\n
Select Dimension to Split or Continue : "
setq
en
entget
s '
setq
ang
cdr
assoc
50
en
defun
*error*
msg
sub2
;| #error |;
princ
\n
Pick New Dimension Point :
\n
setvar
"cursorsize"
1
setq
s1
nil
setq
txt
setq
g
1
while
g
1
setq
gr
grread
t
15
0
;| #grread |;
setq
code
car
gr
setq
po
cadr
gr
cond
code
5
;| Bedune Click |;
cond
s1
entdel
s1
setq
s1
nil
entmod
en
redraw
sub1 s
setq
po33
myortho po1 ang po3
setq
po44
myortho po1 ang po4
setq
dl
distance
po33 po44
setq
ponn
myortho po1 ang po
if
distance
ponn po33
distance
ponn po44
progn
setq
as1
13
setq
as2
14
setq
pot po3
setq
pott po33
progn
setq
as1
14
setq
as2
13
setq
pot po4
setq
pott po44
cond
txt
setq
di
atof
txt
if
and
di dl
not
equal
angle
ponn po33
angle
ponn po44
fuzzy
setq
ponn
polar
pott
angle
pott ponn
di
setq
ponn
polar
pott
angle
pott ponn
di
setq
po
myortho ponn
angle
pott pot
po
if
not
equal
angle
ponn po33
angle
ponn po44
fuzzy
entmod
subst
cons
as1 po
assoc
as1 en
en
setq
asli
list
1
2
5
102
310
300
330
331
340
350
360
410
setq
en1
vl
remove
if
lambda
a
member
car
a
asli
en
setq
s1
entmakex
subst
cons
as2 po
assoc
as2 en1
en1
sub1 s1
princ
strcat
\r
Dimension Distance = "
str
txt
code
3
setq
s s1
setq
s1
nil
setq
en
entget
s '
code
2
cond
member
po '
13
32
;| Enter Space |;
cond
txt
cond
s1
entdel
s1
setq
s1
nil
entmod
en
;;(setq s1 nil)
setq
g
0
po
8
setq
txt
substr
txt
1
1-
strlen
txt
princ
txt
;| #Backspace #substr |;
member
po '
43
45
46
48
49
50
51
52
53
54
55
56
57
setq
txt
strcat
txt
chr
po
;| + - . 0 1 2 3 4 5 6 7 8 9 |;
code
25
cond
s1
entdel
s1
setq
s1
nil
entmod
en
setq
g
0
;| #mouse #right-click |;
sub2
Logged
BIGAL
Swamp Rat
40 + years of using Autocad
Reply #16 on:
November 07, 2023, 05:36:14 PM »
Just a comment for house type plans have drag a line over walls and it makes the dims. All wall lines auto dimmed, is that what your trying to do rather than pick points. Part of a house package so yes a fee.
Last Edit: November 07, 2023, 05:39:42 PM by BIGAL
Logged
ScottMC
Newt
Reply #17 on:
November 09, 2023, 10:45:26 AM »
Very nice and certainly adding to my library. Have not figured it out yet, but the (princ.. Dimension Distance) on line 60, causes it to quit, vlide highlighted it and runs fine without/commented. Thanks
Logged
Print
Pages:
1
2
All
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
Spltting Dimensions
