Author Topic: Move a point in a dynamic block, with a LSP  (Read 1849 times)
Mirko
« on: May 13, 2016, 03:40:07 PM »
Hi everyone!
I've done a dynamic block. To let you know it, I've semplified it (It's to much difficult to exlplain in words...), so:
7
^this is my dynamic block
When i insert my blocks, the point "PT1" of all the block it's never ordered (I must set one by one). So I think i need a LISP that move the point of the dynamic block "FLOOR-DATA" aligned to a point that i set. If I know the height "H" of each frame I can remove the H-value from the Y-value from the point setted.
So a possible operation could be this:
Pick the point (P1): setq P1....
then the lisp, remove the value H (1) from the Y coordinate, from the point (P1). It start from the number "NUM" 1 to the end of the "NUM".
example number 2 will be: P1,Y-1-1 ---> 3 will be: P1,Y-1-1-1 ---> 4 will be: P1,Y-1-1-1-1 etc...
I'm not able to this, because i'm not expert in LISP. I wanted to know if it's possible to do?
Below I made a scheme to make you better understand:
^1
^2
^3
I hope you understand my question...If not ask me
(Attached the example in dwg)
Mirko
Re: Move a point in a dynamic block, with a LSP
« Reply #1 on: May 14, 2016, 10:52:31 AM »
Hi everyone,
I've tried to write with my small knowledge in LSP this:
  1. (setq STARTPOINT (getpoint "\nSpecify the point to start: "))
  2. (setq H (getreal "\nEnter the value of the height :")) ;For me It's 1 (the height value)
  3. (setq STARTPOINT_X (nth 0 STARTPOINT))
  4. (setq STARTPOINT_Y (nth 1 STARTPOINT))
  5. (setq STARTPOINT_Z (nth 2 STARTPOINT))
  6.
  7. (setq NUM (attrubute_from_block_called_NUM))    ;I'm not able to do this
  8. (setq SELECTED_BLOCKS (ssget ....))             ;select the blocks
  9. (repeat_for_al_the_blocks_selected (NUM * H))   ;that increment the distance from the others blocks
  10. (setq New_point_for_the_anchor_point_PT1 (list STARTPOINT_X (- STARTPOINT_Y H) STARTPOINT_Z)) ;set the new point
  11. (repeat_for_al_the_blocks_selected)             ;repeat for all the blocks
  12.
  13. (LM:setdynpropvalue "PT1" (point New_point_for_the_anchor_point_PT1))
  14.
  15. ;; Set Dynamic Block Property Value  -  Lee Mac
  16. ;; Modifies the value of a Dynamic Block property (if present)
  17. ;; blk - [vla] VLA Dynamic Block Reference object
  18. ;; prp - [str] Dynamic Block property name (case-insensitive)
  19. ;; val - [any] New value for property
  20. ;; Returns: [any] New value if successful, else nil
  21.
  22. (defun LM:setdynpropvalue ( blk prp val )
  23.     (setq prp (strcase prp))
  24.     (vl-some
  25.        '(lambda ( x )
  26.             (if (= prp (strcase (vla-get-propertyname x)))
  27.                 (progn
  28.                     (vla-put-value x (vlax-make-variant val (vlax-variant-type (vla-get-value x))))
  29.                     (cond (val) (t))
  30.                 )))
  31.         (vlax-invoke blk 'getdynamicblockproperties)
  32.     )
  33. )
My problems are:
  -  I've inserted some notes, and added a function that I took from http://www.lee-mac.com/dynamicblockfunctions.html#setdynamicpropvalue, but i'm not able to integrate in my code (I've tried but I think I'm wrong)
  -  i'm not able to call and modify a parameter from a dynamic block
Someone could help me in this?  :nerdystraight: because more than this I'm not able to do  :reallysad: :reallysad:
Thank you so much in advance
have a great day
« Reply #2 on: May 15, 2016, 10:58:24 AM »
Please try the following:
  1. (defun c:positionblocks ( / ano blk bpt idx lst obj par sel srt tag val vec )
  2.
  3.     (setq blk "FLOOR-DATA"
  4.           tag "NUM"
  5.           par '("POSIZIONE1 X" "POSIZIONE1 Y")
  6.           vec '(0.0 -1.0 0.0)
  7.     )
  8.
  9.     (if
  10.         (and
  11.             (setq sel
  12.                 (ssget "_:L"
  13.                     (list '(0 . "INSERT")
  14.                         (cons 2
  15.                             (strcat blk
  16.                                 (apply 'strcat
  17.                                     (mapcar '(lambda ( ano ) (strcat ",`" ano))
  18.                                         (LM:getanonymousreferences blk)
  19.                                     )
  20.                                 )
  21.                             )
  22.                         )
  23.                     )
  24.                 )
  25.             )
  26.             (setq bpt (getpoint "\nSpecify base point: "))
  27.             (setq bpt (trans bpt 1 0))
  28.         )
  29.         (progn
  30.             (repeat (setq idx (sslength sel))
  31.                 (if (setq obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))
  32.                           val (LM:vl-getattributevalue obj tag)
  33.                     )
  34.                     (setq srt (cons (atoi val) srt)
  35.                           lst (cons (cons obj (vlax-get obj 'insertionpoint)) lst)
  36.                     )
  37.                 )
  38.             )
  39.             (foreach idx (vl-sort-i srt '<)
  40.                 (LM:setdynprops (car (nth idx lst)) (mapcar 'cons par (mapcar '- bpt (cdr (nth idx lst)))))
  41.                 (setq bpt (mapcar '+ bpt vec))
  42.             )
  43.         )
  44.     )
  45.     (princ)
  46. )
  47.
  48. ;; Set Dynamic Block Properties  -  Lee Mac
  49. ;; Modifies values of Dynamic Block properties using a supplied association list.
  50. ;; blk - [vla] VLA Dynamic Block Reference object
  51. ;; lst - [lst] Association list of ((<Property> . <Value>) ... )
  52. ;; Returns: nil
  53.
  54. (defun LM:setdynprops ( blk lst / itm )
  55.     (setq lst (mapcar '(lambda ( x ) (cons (strcase (car x)) (cdr x))) lst))
  56.     (foreach x (vlax-invoke blk 'getdynamicblockproperties)
  57.         (if (setq itm (assoc (strcase (vla-get-propertyname x)) lst))
  58.             (vla-put-value x (vlax-make-variant (cdr itm) (vlax-variant-type (vla-get-value x))))
  59.         )
  60.     )
  61. )
  62.
  63. ;; Get Attribute Value  -  Lee Mac
  64. ;; Returns the value held by the specified tag within the supplied block, if present.
  65. ;; blk - [vla] VLA Block Reference Object
  66. ;; tag - [str] Attribute TagString
  67. ;; Returns: [str] Attribute value, else nil if tag is not found.
  68.
  69. (defun LM:vl-getattributevalue ( blk tag )
  70.     (setq tag (strcase tag))
  71.     (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (vla-get-textstring att)))
  72.         (vlax-invoke blk 'getattributes)
  73.     )
  74. )
  75.
  76. ;; Get Anonymous References  -  Lee Mac
  77. ;; Returns the names of all anonymous references of a block.
  78. ;; blk - [str] Block name/wildcard pattern for which to return anon. references
  79.
  80. (defun LM:getanonymousreferences ( blk / ano def lst rec ref )
  81.     (setq blk (strcase blk))
  82.     (while (setq def (tblnext "block" (null def)))
  83.         (if
  84.             (and (= 1 (logand 1 (cdr (assoc 70 def))))
  85.                 (setq rec
  86.                     (entget
  87.                         (cdr
  88.                             (assoc 330
  89.                                 (entget
  90.                                     (tblobjname "block"
  91.                                         (setq ano (cdr (assoc 2 def)))
  92.                                     )
  93.                                 )
  94.                             )
  95.                         )
  96.                     )
  97.                 )
  98.             )
  99.             (while
  100.                 (and
  101.                     (not (member ano lst))
  102.                     (setq ref (assoc 331 rec))
  103.                 )
  104.                 (if
  105.                     (and
  106.                         (entget (cdr ref))
  107.                         (wcmatch (strcase (LM:al-effectivename (cdr ref))) blk)
  108.                     )
  109.                     (setq lst (cons ano lst))
  110.                 )
  111.                 (setq rec (cdr (member (assoc 331 rec) rec)))
  112.             )
  113.         )
  114.     )
  115.     (reverse lst)
  116. )
  117.
  118. ;; Effective Block Name  -  Lee Mac
  119. ;; ent - [ent] Block Reference entity
  120.
  121. (defun LM:al-effectivename ( ent / blk rep )
  122.     (if (wcmatch (setq blk (cdr (assoc 2 (entget ent)))) "`**")
  123.         (if
  124.             (and
  125.                 (setq rep
  126.                     (cdadr
  127.                         (assoc -3
  128.                             (entget
  129.                                 (cdr
  130.                                     (assoc 330
  131.                                         (entget
  132.                                             (tblobjname "block" blk)
  133.                                         )
  134.                                     )
  135.                                 )
  136.                                '("acdbblockrepbtag")
  137.                             )
  138.                         )
  139.                     )
  140.                 )
  141.                 (setq rep (handent (cdr (assoc 1005 rep))))
  142.             )
  143.             (setq blk (cdr (assoc 2 (entget rep))))
  144.         )
  145.     )
  146.     blk
  147. )
  148.
The above uses the following library functions:
Get Attribute Value
Mirko
« Reply #3 on: May 15, 2016, 02:37:10 PM »
WOOOOWW Thanks very much Lee Mac :) It works perfectly!! :) :)
Your website and the library functions are very very interesting! (although many are complicated to understand, since I'm a beginner in lisp)
I've another little question..
I've tried  to change your lisp, to allow  to work even if I select 2 blocks with different name (with same attributes and parameters)...In ths way I could use it also for an another block for the windows....The problem is that the modify I've done doesen't work...
  2.
  3.     (setq tag "NUM"
  4.           par '("POSIZIONE1 X" "POSIZIONE1 Y")
  5.           vec '(0.0 -1.0 0.0)
  6.     )
  7.
  8.     (if
  9.         (and
  10.             (setq sel
  11.                 (ssget "_:L"
  12.                     (list '(0 . "INSERT")
  13.                         (cons 2
  14.                                 (apply 'strcat
  15.                                     (mapcar '(lambda ( ano ) (strcat ",`" ano))
  16.                                         (LM:getanonymousreferences blk)
  17.                                     )
  18.                                 )
  19.                         )
  20.                     )
  21.                 )
  22.             )
  23.             (setq bpt (getpoint "\nSpecify base point: "))
  24.             (setq bpt (trans bpt 1 0))
  25.         )
  26.         (progn
  27.             (repeat (setq idx (sslength sel))
  28.                 (if (setq obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))
  29.                           val (LM:vl-getattributevalue obj tag)
  30.                     )
  31.                     (setq srt (cons (atoi val) srt)
  32.                           lst (cons (cons obj (vlax-get obj 'insertionpoint)) lst)
  33.                     )
  34.                 )
  35.             )
  36.             (foreach idx (vl-sort-i srt '<)
  37.                 (LM:setdynprops (car (nth idx lst)) (mapcar 'cons par (mapcar '- bpt (cdr (nth idx lst)))))
  38.                 (setq bpt (mapcar '+ bpt vec))
  39.             )
  40.         )
  41.     )
  42.     (princ)
  43. )
What I'm wrong?
« Reply #4 on: May 15, 2016, 07:23:00 PM »
You're most welcome - I'm glad the code is working well.
Below is a modified version to remove the block name restriction:
  1. (defun c:positionblocks ( / bpt idx lst obj par sel srt tag val vec )
  2.
  3.     (setq tag "NUM"
  6.     )
  7.     (if (and (setq sel (ssget "_:L" '((0 . "INSERT"))))
  8.              (setq bpt (getpoint "\nSpecify base point: "))
  9.              (setq bpt (trans bpt 1 0))
  10.         )
  11.         (progn
  12.             (repeat (setq idx (sslength sel))
  13.                 (if (setq obj (vlax-ename->vla-object (ssname sel (setq idx (1- idx))))
  14.                           val (LM:vl-getattributevalue obj tag)
  15.                     )
  16.                     (setq srt (cons (atoi val) srt)
  17.                           lst (cons (cons obj (vlax-get obj 'insertionpoint)) lst)
  18.                     )
  19.                 )
  20.             )
  21.             (foreach idx (vl-sort-i srt '<)
  22.                 (LM:setdynprops (car (nth idx lst)) (mapcar 'cons par (mapcar '- bpt (cdr (nth idx lst)))))
  23.                 (setq bpt (mapcar '+ bpt vec))
  24.             )
  25.         )
  26.     )
  27.     (princ)
  28. )
  29.
  30. ;; Set Dynamic Block Properties  -  Lee Mac
  31. ;; Modifies values of Dynamic Block properties using a supplied association list.
  32. ;; blk - [vla] VLA Dynamic Block Reference object
  33. ;; lst - [lst] Association list of ((<Property> . <Value>) ... )
  34. ;; Returns: nil
  35.
  36. (defun LM:setdynprops ( blk lst / itm )
  37.     (setq lst (mapcar '(lambda ( x ) (cons (strcase (car x)) (cdr x))) lst))
  38.     (foreach x (vlax-invoke blk 'getdynamicblockproperties)
  39.         (if (setq itm (assoc (strcase (vla-get-propertyname x)) lst))
  40.             (vla-put-value x (vlax-make-variant (cdr itm) (vlax-variant-type (vla-get-value x))))
  41.         )
  42.     )
  43. )
  44.
  45. ;; Get Attribute Value  -  Lee Mac
  46. ;; Returns the value held by the specified tag within the supplied block, if present.
  47. ;; blk - [vla] VLA Block Reference Object
  48. ;; tag - [str] Attribute TagString
  49. ;; Returns: [str] Attribute value, else nil if tag is not found.
  50.
  51. (defun LM:vl-getattributevalue ( blk tag )
  52.     (setq tag (strcase tag))
  53.     (vl-some '(lambda ( att ) (if (= tag (strcase (vla-get-tagstring att))) (vla-get-textstring att)))
  54.         (vlax-invoke blk 'getattributes)
  55.     )
  56. )
  57.
Mirko
« Reply #5 on: May 16, 2016, 04:10:56 AM »
have a great day
« Reply #6 on: May 16, 2016, 04:14:05 AM »
You too Mirko  :-)
