Author Topic: Access to Sheet Set components  (Read 4613 times)
pBe
« on: May 12, 2016, 02:17:50 AM »
What is the equivalent of vla-item in .NET
Code - C#: [Select]
  1.
  2.             // Get a reference to the Sheet Set Manager object
  3.             IAcSmSheetSetMgr sheetSetManager = default(IAcSmSheetSetMgr);
  4.             sheetSetManager = new AcSmSheetSetMgr();
  5.
  6.             // Open a Sheet Set file
  7.             AcSmDatabase sheetSetDatabase = default(AcSmDatabase);
  8.             sheetSetDatabase = sheetSetManager.OpenDatabase(DSTPath, true);
  9.
  10.             // Get the sheet set from the database
  11.             AcSmSheetSet sheetSet = sheetSetDatabase.GetSheetSet();
  12.
  13.           AcSmSubset = < I  know the name of the subset >
  14.
  15.
< That > is the part where i'm stumped.
How do you access a Subset of a known "name": subset on a sheet set? similar to  (vla-item SheetSetCollection "Irrigation")
Code - C#: [Select]
  1.                 AcSmSubset subset = default(AcSmSubset);
  2.                 subset = (sheetSetDatabase.GetName(), SubsetName);
Thank you
pBe
n.yuan
Re: Access to Sheet Set components
« Reply #1 on: May 12, 2016, 10:23:09 AM »
Look into:
AcSmSheetSet.GetSheetEnumerator() method, which returns an IAcSmEnumComponent. Something like:
var iterator = sheetSet.GetSheetEnumerator()
var sheet=iterator.Next() as AcSmSheet
while (sheet!=null)
    //Do somethign with the sheet
    iterator.Next()
nobody
  • .net stuff
« Reply #2 on: May 13, 2016, 01:10:47 AM »
Not sure anything is equal between the two.  For me, maybe a close equal to a vlax dump would be the intellisense in Visual Studio.  Had to break my brain to learn .Net after using lisp for so many years.
ChrisCarlson
« Reply #3 on: May 13, 2016, 07:59:28 AM »
I didn't think you could access the SSM from Lisp?
dgorsman
« Reply #4 on: May 13, 2016, 10:15:29 AM »
There are tons of equivalencies of (vla-Item ...) in dotNET.  The function is used to get an entry from an indexed collection, similar to an Item() or ElementAt() method.  In dotNET the method of accessing a collection will depend on the type of collection.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
nobody
  • .net stuff
« Reply #5 on: May 14, 2016, 08:03:41 PM »
pBe
« Reply #6 on: May 23, 2016, 10:01:43 AM »
Thank you for that Area51Visitor.
I have this to retrieve the Sheet Set ObjectID.
Code - C#: [Select]
  1.
  2.     [CommandMethod("RetriveInfoSSM")]
  3.         public void RetriveInfoSSM()
  4.         {
  5.
  6.             IAcSmSheetSetMgr sheetSetManager = default(IAcSmSheetSetMgr);
  7.             sheetSetManager = new AcSmSheetSetMgr();
  8.
  9.             AcSmDatabase sheetSetDatabase = default(AcSmDatabase);
  10.             sheetSetDatabase = sheetSetManager.OpenDatabase("Z:\\Placholder\\Sheet Set Template.dst", false);
  11.
  12.             MessageBox.Show(sheetSetDatabase.GetObjectId().GetHandle());
  13.
  14.             sheetSetManager.Close(sheetSetDatabase);
  15.         }
  16.
Question:
Instead of MessageBox.Show, is there way to pass the value to a variable that will be available upon command exit?
Look into:
AcSmSheetSet.GetSheetEnumerator() method, which returns an IAcSmEnumComponent. Something like:........
I'm still working on this one :). From what I've gathered . IAcSmEnumComponent is indeed the way to go about it.
nobody
  • .net stuff
« Reply #7 on: May 23, 2016, 10:24:42 PM »
I'm assuming pass it so you can use it with autolisp. Correct me if I'm wrong.
I've not done that myself but my gut tells me to use currentDocument.SendStringToExecute() but the formatting will be a bit tricky...see below for an example.
currentDocument.SendStringToExecute("(setq test (append test (list \"" + i.ToString() + "\")) ) ", true, false, false);
IMO this is like using a wrecking ball to do a hammers job. I can't stress how much I'd recommend pressing on with c# and .net though.  It's strange at first, the debug is a pain compared to writing directly in the command line with lisp, but in the end I think you'd find it hard to want to write in lisp again. dot-net just has too many benefits.
Question:
« Last Edit: May 23, 2016, 10:32:04 PM by Area51Visitor »
pBe
« Reply #8 on: May 24, 2016, 12:15:26 AM »
Thank you for the tip.
Somehow I knew you're going to say that. :D, I started watching video tutorials of C# by Bob Tabor [Channel 9] and browse thru Little Wonder series. by James Michael Hare posted by Kerry, and I also bought a book by Pat McGee and i like what I'm seeing.
But right now, the program is 90 % done < in lisp >, I just need to run a program with the HELP of .NET. on the 10% [ Sheet Set side of things ]. so please bear with me with on this.
I will definitely re-write the whole thing when I know enough .NET.
Thank you for all your help.
pBe
« Reply #9 on: May 24, 2016, 01:29:14 AM »
Thank you Area51visitor, SendStringToExecute works.
Code - Text: [Select]
  1. string Tolisp = sheetSetDatabase.GetObjectId().GetHandle();
  2. acDoc.SendStringToExecute("(_fromNet \"" + Tolisp +"\") ", true, false, false);
nobody
  • .net stuff
« Reply #10 on: May 24, 2016, 04:42:48 AM »
Glad it worked!
pBe
« Reply #11 on: May 24, 2016, 07:45:16 AM »
  1. AcSmCustomPropertyValue SSMCustValue = new AcSmCustomPropertyValue();
  2. SSMCustValue.GetValue();
Why am I getting a value of  System.__ComObject ?
Apparently the value is a variant
Tried
  1.  SSMCustValue.ToString();
Same result though.
  1. SSMCustValue.GetValue().ToString()
Crashed !
Any thoughts?
pBe
« Reply #12 on: May 25, 2016, 06:34:32 AM »
As it turned out, I just need to add MicrosoftCSharp.DLL to "Reference" , Saw the error message on Error List window.
and use GetValue() without the .ToString to get the string value
All I need to do now is "Grab" the list from .Net and pass the values to lisp.....
nobody
  • .net stuff
« Reply #13 on: May 26, 2016, 03:21:33 AM »
Nice. Glad you figured it out!
