Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
about division round
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: about division round (Read 895 times)
dussla
Bull Frog
on:
May 09, 2016, 10:21:28 AM »
hello ~
i need some help ~
( / 200 1000 )
= 0.2
but result
(rtos ( / 200 1000 ) 2 2)
"0"
why "0"
i want 0.2
can you help ~
Logged
Needs a day job
Re: about division round
Reply #1 on:
May 09, 2016, 10:26:50 AM »
Hint:
Code:
[Select]
( / 200. 1000. )
Also look into the
FLOAT
function.
Last Edit: May 09, 2016, 10:43:28 AM by ronjonp
Logged
Administrator
Seagull
Reply #2 on:
May 09, 2016, 10:37:15 AM »
Floating point / Decimal division.
Code - Auto/Visual Lisp:
[Select]
foreach
mode '
1
2
3
4
5
write-line
strcat
"RTOS "
rtos
mode
rtos
100.0
2000.0
mode
EDIT: See ronjonp's post above mine.
Logged
TheSwamp.org
(serving the CAD community since 2003)
dgorsman
Water Moccasin
Reply #3 on:
May 09, 2016, 02:42:37 PM »
Slightly more detail - when you provide two integers to the LISP math functions, it returns an integer. If at least one of the arguments is a floating point, the return value is also floating point.
Logged
try {GreatPower;}
catch (notResponsible)
{NextTime(PlanAhead);}
finally
{MasterBasics;}
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
