Author Topic: Blend 2 solids at edge  (Read 19271 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« on: April 30, 2016, 09:58:37 PM »
I'm wondering if I've forgotten something ....
I needed to blend adjacent solids (representing steel plates).
Currently I'm using some code I've written to query the complimentary dihedral angle for the plate edges, divide it by 2 and add that value to the clipboard in code.
Then I apply a taper manually to each edge using the value on the clipboard for the taper angle.
I'm wondering if there is a built in command I've missed to do this process .
Here's a ToDo and a DonePreviously piccy to help visualise the product.
added for the inquisitive :
The assembled petals represent the facets of a square to round transition chute.
The petals are flat rather than conical because they will have flat removable wear plates bolted inside to protect the chute walls from the abrasive product.
Each of the crease line will be 'pressed' on the wall plate.
Regards,
« Last Edit: April 30, 2016, 10:05:52 PM by kdub »
Called Kerry in my other life
I live at UTC + 13.00
some people complain about loading the dishwasher
SEANT
Re: Blend 2 solids at edge
« Reply #1 on: May 01, 2016, 06:16:21 AM »
I know I may be missing something about the starting parameters, or the necessary end result, but does this sequence of commands help at all?
Sean Tessier
AutoCAD 2016 Mechanical
Master_Shake
« Reply #2 on: May 02, 2016, 08:01:33 AM »
I would do the loft / thicken method as looking at your screen shot, you can easily fix the outside but the inside has two vertices instead of 1.
« Reply #3 on: May 02, 2016, 10:18:00 AM »
I wonder if an interference surface would be what you are after?
Or even if UNION would not resolve those gaps?
kdub_nz
  • SuperMod
« Reply #4 on: May 02, 2016, 12:11:51 PM »
I'll have a further play with loft and thicken, when I get some spare time.
I had tried that but may have missed some of the nuances.
MJ,
UNION does not add material, it joins what is there.
How would an interference surface help me ?
Thanks for the input.
« Reply #5 on: May 02, 2016, 12:15:48 PM »
MJ,
The interference surface might fill in the gaps...
I was also considering a procedural method, of the nature of how they will have to actually make the thing...
either by bending or welding plates together.
Will try to post example...
kdub_nz
  • SuperMod
« Reply #6 on: May 02, 2016, 12:22:03 PM »
Here's a geometry template for anyone who wants to play.
I've saved back to ac2007.
kdub_nz
  • SuperMod
« Reply #7 on: May 02, 2016, 12:27:02 PM »
As stated in the first post, the plates are pressed ( bent) the dihedral ranges from 150 to 170 degrees
I do need the petals as separate solids but I can slice the crease lines if necessary.
« Reply #8 on: May 02, 2016, 01:12:58 PM »
this is the procedural way...
square to round...
draw 1/4 each square and round section
divide into desired number of 'bends' to achieve shape transition
offset plate thickness...
draw 3dfaces
convert to mesh
union them into 3d solids...
a bit tedious, however appears to give proper geometry for each plate making up the square to round transition....
kdub_nz
  • SuperMod
« Reply #9 on: May 02, 2016, 01:29:03 PM »
Michael, I assume you know nothing of steel fabrication.
Why are you twisting the plates ?
« Reply #10 on: May 02, 2016, 02:11:48 PM »
If one is going from a flat edge to a circular edge...there will be some twist
or one will need to use triangular sections to fill between...
« Reply #11 on: May 02, 2016, 02:13:38 PM »
From the limited view in your original post...it looks as if you are also not using a standard development for square to round...
kdub_nz
  • SuperMod
« Reply #12 on: May 02, 2016, 02:18:19 PM »
Sheet metal work is different to structural steel where the plates have a significant thickness.
If you had looked at the template I provided you would have seen the methodology involved.
Read my first post again. There is an explicit requirement for flat planar petals.
That aside, thanks for your input.
« Reply #13 on: May 02, 2016, 02:49:10 PM »
I just grabbed your geometry template...Pretty sure IF I use similar methods as with mine, the petals will also appear to be twisted....only they will just be tangent to the arcs in those decreasing radii....
kdub_nz
  • SuperMod
« Reply #14 on: May 03, 2016, 01:51:00 AM »
Just for info :
This is what it looks like without the wear plates fitted (bolted)  inside.
and a flat template of one of the corners
.... and a dwg file.
« Last Edit: May 03, 2016, 01:58:01 AM by kdub »
