Author Topic: attribute edit  (Read 7183 times)
AIberto
Re: attribute edit
« Reply #15 on: April 18, 2016, 10:32:22 AM »
Can you post a sample drawing? The program works on the sample dwgs I have that sport attributed blocks with promptless attdefs. Thanks.
In attachment . Just an attribute block without "prompt"
command: MyEd
Select object: ; error: Unknown exception occurred
; warning: unwind skipped on unknown exception
« Last Edit: April 18, 2016, 11:16:54 AM by AIberto »
Re: attribute edit
« Reply #16 on: April 18, 2016, 10:35:59 AM »
Thanks AIberto. Could you (or someone else) perform a "SaveAs" down to 2010 format?
I only have AutoCAD 2012 here and no TrueView install.
Thanks and sorry (I should have specified).
« Last Edit: April 18, 2016, 10:49:43 AM by MP »
AIberto
Re: attribute edit
« Reply #17 on: April 18, 2016, 11:19:44 AM »
I'm sorry , MP  ,I forgot converted.
Re: attribute edit
« Reply #18 on: April 18, 2016, 11:48:06 AM »
Sorry AIberto but that's still a 2013 version dwg.
Re: attribute edit
« Reply #19 on: April 18, 2016, 11:51:20 AM »
Here you go :)
Re: attribute edit
« Reply #20 on: April 18, 2016, 11:56:25 AM »
Thanks Ronjonp.
Both programs work on the sample drawing without incident.
¯\_(ツ)_/¯
AIberto
Re: attribute edit
« Reply #21 on: April 18, 2016, 12:15:09 PM »
Thanks Ronjonp.
¯\_(ツ)_/¯
I use different PC, different CAD version (2013, 2010) for test . the same error.
Re: attribute edit
« Reply #22 on: April 18, 2016, 12:17:24 PM »
Don't know what to tell you, cannot replicate the error here.
Can anyone else replicate the error? Thanks & cheers.
Marc'Antonio Alessi
  • Marco
Re: attribute edit
« Reply #23 on: April 18, 2016, 12:25:32 PM »
Tested here on 2013 ITA, MyEd & Prompter: OK    :-)
Re: attribute edit
« Reply #24 on: April 18, 2016, 12:27:28 PM »
Thank you for testing and attesting sir.  :-)
AIberto
Re: attribute edit
« Reply #25 on: April 18, 2016, 10:04:54 PM »
I use acad2010 ,windows XP sp3 , DOSLib18.arx,
Break at:
(dos_proplist "MyEd" "Modify Attributes"
(mapcar
(function (lambda ( a ) (cons (car a) (cadr a))))
attribs
 mean:  if "prompt" is empty . must use other routine "c:Prompter" to modify attribute prompts , make it not empty .  Then use "Myed" ?
Marc'Antonio Alessi
  • Marco
Re: attribute edit
« Reply #26 on: April 19, 2016, 02:28:49 AM »
No, I used MyEd & Prompter on your file just opened and not modified in two different sessions and loading only one function at a time...  :yes:
AIberto
Re: attribute edit
« Reply #27 on: April 19, 2016, 08:16:44 AM »
Dear sir.
I testing. Break at:
   (mapcar
      attribs
You analyze why appear error ?
Re: attribute edit
« Reply #28 on: April 19, 2016, 10:26:01 AM »
Hi AIberto.
  • While MyEd and Prompter both work with some aspect of attributes they are fully independent.
  • Is DOSLIB (http://wiki.mcneel.com/doslib/home) installed and loaded?
  • Define and load this error handler: (defun *error* (m) (vl-bt)).
  • Execute the program and post the error messages you see.
AIberto
Re: attribute edit
« Reply #29 on: April 20, 2016, 08:38:41 AM »
Hi AIberto.
windos xp 32bit+ acad2010 +doslib18.arx
DOSLib18.arx successfully loaded.
Command: myed
Command: (defun *error* (m) (vl-bt))
*ERROR*
