Author Topic: More deployment questions, this time regarding the .bundle  (Read 2148 times)
Atook
  • AKA Tim
« on: April 09, 2016, 07:09:19 PM »
I’m trying to figure out the .bundle format, but I can’t seem to get it to load.
I’m basing the .bundle from Giles excellent ConverterPalette example, and perusing the Autodesk Knowledge Network.
The contents of the bundle include:
  • .NET DLL
  • CSV files for data
  • .dwtTemplate
I’ve copied the .bundle into
C:\Program Files\Autodesk\ApplicationPlugins - didn’t load.
C:\ProgramData\Autodesk\ApplicationPlugins – didn’t load.
I can see that autocad is loading the other bundles from C:\ProgramData\Autodesk\ApplicationPlugins but for some reason my AID.bundle is not loading.
From the command prompt at startup I can see that the bundles right next to mine are getting loaded.
I’m wondering if I’m not making the PackageContents.xml file, but I’m not sure what it would be. Do I need to include the CSV and dwt file as components in the xml? It seems to me that components are reserved for dll files.
Lastly, is there some tool I should be using to create the .bundle or xml file?
Edit: Download removed.
« Last Edit: April 11, 2016, 03:51:58 PM by Atook »
Re: More deployment questions, this time regarding the .bundle
« Reply #1 on: April 10, 2016, 11:04:29 AM »
FYI, I was prompted to not follow the link you provided. Not sure if it was my ISP or Avast, but it wasn't pretty. I ignored the warnings and grabbed the zip, but....
« Reply #2 on: April 10, 2016, 11:13:50 AM »
Your bundle loaded for me, as it was shown as being successfully loaded (which does not load the dll since you hav ethe LoadOnCommandInvocation set to True). I then typed one of the commands listed in the bundle and it loaded:
Command: IR_InsValve
Reading Default Sprinklers..
Attempting to open folder: C:\ProgramData\Autodesk\ApplicationPlugins\AID.bundle\Contents
Opening C:\ProgramData\Autodesk\ApplicationPlugins\AID.bundle\Contents\AID_SprinklerTable.csv
Total Lines Read: 3019 - 3019 sprinklers added
Reading Pipes..Attempting to open folder: C:\ProgramData\Autodesk\ApplicationPlugins\AID.bundle\Contents
Opening C:\ProgramData\Autodesk\ApplicationPlugins\AID.bundle\Contents\AID_PipeDatabase.csv
Total Lines Read: 111
110 pipes added
Reading Setting Default Lateral Pipe..
Syncing tool palette
Initialization complete, enjoy!
However, I was then greeted with an unhandled exception error, Object reference not set to an instance of an object.
Atook
  • AKA Tim
« Reply #3 on: April 11, 2016, 03:34:10 AM »
Thanks for the feedback Jeff, I'll need to look into why it doesn't seem to load on my test machine in the same path. At least I know I don't need to beat my head against the keyboard nitpicking the xml file!
I'll need to look into the LoadOnCommandInvocation flag.
The unhandled object is on my end, referring to a palette object that probably wasn't loaded. I'm still working on my architecture there. :)
Regarding the error on my server, it's because it's an https connection, and I apparently don't have the right config for my SSL cert from letsencrypt.  I'm hoping I got it sorted now, but it's hard to tell from inside my network sometimes.
Atook
  • AKA Tim
« Reply #4 on: April 11, 2016, 03:27:32 PM »
Jeff, thanks again for your feedback. Setting the LoadOnCommandInvocation to false allowed me to see that it was in fact loading.
The reason I wasn't getting the commands loaded that I wanted, was because I had accidently left them out of the xml file. Basically any [CommandMethod] in my .NET project should be included in the PackageContents.xml.
« Reply #5 on: April 11, 2016, 03:32:14 PM »
You're welcome. If you have your code doing anything that should be done at startup, I'd leave the commands out of the xml file and just have the add-on load at startup instead of commandinvocation. This does slow down the initial startup of Autocad, but it speeds up the loading of the command...and saves from having to enter 200+ commands to the xml file.
Atook
  • AKA Tim
« Reply #6 on: April 11, 2016, 03:52:48 PM »
.. I'd leave the commands out of the xml file and just have the add-on load at startup instead of commandinvocation. This does slow down the initial startup of Autocad, but it speeds up the loading of the command...and saves from having to enter 200+ commands to the xml file.
Great information to have, thanks again!
