Windows 7 x64
Visual Studio 2015 Update 1.
AutoCAD 2016 SP1 x64
.Net Framework 4.6.1
I have a problem when my WCF service is hosted by
accoreconsole.exe instead of
acad.exe: the client application (the console application) can't interact with it. Both cases servise was opened successfully and
telnet works fine with the necessary port. I use HTTP protocol. I haven't this problem when the host is
acad.exe (for the same client application).
For this problem demonstration I created
the simple solution with two projects: client and service. Detailed info about each of them is discribed in their
readme.md files. The problem with screens is described in the
readme.md of the solution.
NOTE
It is necessary to read
readme.md files, because they contain important info. For building this solution you are to launch Visual Studio with admin rights.
I will be very grateful for the explanation of the reasons of this problem.
Best regards, Andrey.
