Author Topic: extrusion code  (Read 6970 times)
Zahex
extrusion code
« on: May 11, 2005, 07:40:58 AM »
Hi can anyone give me a help with this code?i marked the line that doesn't work and what i want it to do.
i want to extrude using the taper angle option one polygon defined by a user to another also defined by the user.
give it a look the only problem is that it only works because i fixed the values.
please help...
(alert "to run type 2")
;;;   (command "erase" "all" "")  comment added by CAB
(defun c:2 ()
  (setq angl (atan (/ 5 3))) ; here is the problem the idea was to replace 5 by height and 3 by larger radius-smaller radius this is the only way to return the angle for the taper angle extrusion
  (setq baseradius (getreal "\n smaller radius: "))
  (setq height (getreal "\n height: "))
  (setq sides (getint "\n number of polygon sides: ")
    centerpt (getpoint "\n insertion point: ")
    radius (getreal "\n larger radius: ")
    osnaps (getvar "osmode")
  ); setq
  (setvar "osmode" 0)
  (command "polygon" sides centerpt "C" (polar centerpt 0 radius))
  (command "extrude" (entlast) "" height angl)
extrusion code
« Reply #1 on: May 11, 2005, 08:10:09 AM »
This [ (command "erase" "all" "") ] may not bother anyone else but it may be a good idea not to include that in your code when posting it. Might give someone a shock if they didn't catch that in your code.
daron
extrusion code
« Reply #2 on: May 11, 2005, 08:49:33 AM »
I saw that. Was wondering why you'd erase everything in your drawing whenever you load that file? Could be very dangerous.
extrusion code
« Reply #3 on: May 11, 2005, 09:07:15 AM »
I concur with previous comments.
Also, was it your intention to perform integer math?
(/ 5 3) => 1
(/ 5 3.0) => 1.66667
Thus ...
(atan (/ 5 3)) => 0.785398
(atan (/ 5 3.0)) => 1.03038
Zahex
forget numbers 3 and 5
« Reply #4 on: May 11, 2005, 09:50:38 AM »
Yes you're right about the erase all thing how do i change it so people don't be shocked?
Forget the 5 and 3 values that's not what this is about,5 and 3 are just examples.
5 should be replaced by a variable height previously defined by the user.
3 should be replaced by a subtraction of two variables,between the bigger radius and the smaller radius(top and base can take both types of radius).
please help
daron
extrusion code
« Reply #5 on: May 11, 2005, 10:32:57 AM »
What's the purpose of erasing all objects in db?
extrusion code
« Reply #6 on: May 11, 2005, 10:46:39 AM »
Checking batteries in crystal ball ...
Zahex
extrusion code
« Reply #7 on: May 11, 2005, 12:25:45 PM »
this is what i want to do,only this code asks me for 2 radius but still it draws me a pyramid and not a prismatic figure.
Any ideas?
(defun c:2 ()
(setq radius (getreal "\n larger radius: "))
(setq angRad (atan height (- radius baseradius)))
(setq angDeg (Radians->Degrees angRad))
(setq sides (getint "\n number of polygon sides: "))
(setq centerpt (getpoint "\n insertion point: "))
(setq osnaps (getvar "osmode"))
(setvar "osmode" 0)
(command "extrude" (entlast) "" height angDeg)
(defun Radians->Degrees (rads)
(* rads (
CADaver
extrusion code
« Reply #8 on: May 11, 2005, 01:06:27 PM »
dunno, try these
(defun dtr (a)(* pi (/ a 180.0)))
(defun rtd (a)(* 180.0 (/ a pi)))
(command "polygon" sides centerpt "C" radius)no need for polar
(setq angdeg (- 90.0 (rtd (atan height (- radius baseradius)))))no need to set and save angrad
Zahex
where do i put them
« Reply #9 on: May 11, 2005, 01:20:47 PM »
exactly where do i pu them in my code?
CADaver
extrusion code
« Reply #10 on: May 11, 2005, 01:45:22 PM »
the two function rtd and dtr go first, above everything.
for the other two lines, just replace your lines in the code with those.  where you're calling the polygon command, replace it with that line, and where you're defining angdeg replace that line with mine, then delete the (setq andrad line completely.
then give it a shot.
Zahex
Like this?
« Reply #11 on: May 11, 2005, 04:26:06 PM »
Like this?
(defun c:2 ()
(setq angDeg (- 90.0 (rtd (atan height (- radius baseradius)))))
(setvar "osmode" 0)
(* rads (/ 180.0 pi)))
CADaver
Re: Like this?
« Reply #12 on: May 11, 2005, 04:37:28 PM »
sorta Like this? completely unchecked.
(defun c:2 ()
(command ".undo" "begin")
    (setvar "osmode" 0)
  (setvar "osmode" osnaps)
(command ".undo" "end")
daron
extrusion code
« Reply #13 on: May 12, 2005, 07:27:41 AM »
Always keep a backup of your work before making suggested changes.
CADaver
extrusion code
« Reply #14 on: May 12, 2005, 08:49:37 AM »
Quote from: Daron
excellent advice... i'm quite surprised CAB hasn't jumped in yet with some simply marvelous code for this.  i've grown to depend on his participation to keep me out of trouble...  well, him and nearly everyone else here.
