Author Topic: XREF MText Background Shown As Solid Fill?  (Read 9087 times)
BlackBox
« on: March 28, 2016, 10:59:40 AM »
Does anyone know the cause for why all XREF Dimensions, MText, and MLeaders with background fill enabled (as background color) would start showing up as solid fill, as in I cannot see the text contents?
Again, only the XREF-ed annotations; I have annotations within the current drawing with same background fill enabled (as background color), and they look/plot as expected.
When I open the source XREF, they appear normally (as background color), and only XREF annotations to that drawing show as solid fill.
I've audited, and recovered the XREFs, and nothing changes - they still show up as a color filled rectangle, and plot solid black. :|
BlackBox
Re: XREF MText Background Shown As Solid Fill?
« Reply #1 on: March 28, 2016, 11:10:10 AM »
Opened the same drawing(s) in 2015 (using 2016 above), and there's no issue - so this seems to be an application setting.
« Reply #2 on: March 28, 2016, 11:16:36 AM »
what is your view type?
2d wireframe?  or what?
BlackBox
« Reply #3 on: March 28, 2016, 11:20:44 AM »
Found the culprit... XREFOVERRIDE == 1
How/why would that cause annotation background fills (as background color) to show as being solid color fill? *confused*
« Reply #4 on: March 28, 2016, 11:22:32 AM »
The XREFOVERRIDE system variable affects display and plotting, and works in conjunction with the VISRETAIN system variable. If you want the xref layers to retain their original layer settings, it is recommended to set VISRETAIN and XREFOVERRIDE system variables to 0.
0   When the properties of the objects (such as color, linetype, lineweight, transparency, or plot style) on the external reference drawing are set to ByLayer, any changes to the xref layer properties are displayed in the current drawing (legacy behavior)
1   When the visual properties of the objects on the external reference drawing are not set to ByLayer, objects on xref layers are treated as if their properties are set to ByLayer and every external reference layer can have its own set of layer overrides
« Reply #5 on: March 28, 2016, 11:23:42 AM »
It would appear that those background masks are NOT a BYLAYER setting...at least as far as autocad is concerned, so they get whacked
BlackBox
« Reply #6 on: March 28, 2016, 11:24:49 AM »
I've read the help - what I don't understand is why masking is included?
Setting the background fill to ByLayer pretty much defeats the purpose of having a mask enabled in the first place, as not even the text within can be seen.
« Reply #7 on: March 28, 2016, 11:31:15 AM »
Yeah well, not everything those folks at autodesk dreams up works the way we would like it to, nor does it always work the way they intended it to either...
a good example, Sheet Sets, when first introduced they claimed on could use things like repetitive details sheets over and over in multiple sets...
then it later turns out, OOPS  no you cant, without making a copy of the dumb sheet, which is what SSM was supposed to help you stop doing...
by the way, it's still broken and they want us to accept it that way
BlackBox
« Reply #8 on: March 28, 2016, 11:38:27 AM »
Thanks anyway, Michael - just glad to get it fixed at this point (by setting XREFOVERRIDE == 0).
« Reply #9 on: March 28, 2016, 11:49:51 AM »
of interest The XREFOVERRIDE system variable seems to be set to 0 (off) by default.
Perhaps it has been set to 1 (on) in your template(s)?
BlackBox
« Reply #10 on: March 28, 2016, 01:06:04 PM »
No - just futzing around last Thursday to see if this would be of benefit, and it clearly is not (to me, at this time), for the reasons above. I was on vacation Friday, and neglected to change it back before I left. Didn't affect 2015, as it didn't exist. :-)
Jeff H
« Reply #11 on: March 29, 2016, 04:50:42 AM »
had problems causing text with fields unusable in xref with it set to 1. Had to turn off field display
« Reply #12 on: March 29, 2016, 08:35:47 AM »
looks like dev team never bothered to test this 'new' tool in the real world
otherwise we would not be fighting these obvious (to us) undesirable effects
« Reply #13 on: March 29, 2016, 08:38:59 AM »
Honestly, you should totally blame all the beta testers. That is just a total lack of their part. *sigh*
« Reply #14 on: March 29, 2016, 09:03:41 AM »
I might be inclined to, except without know what the testers were asked to test...it could be that no one asked them to look for this particular behavior
and it got overlooked
however IF anyone here was on that beta testing team, I will wait for their comments before drawing any conclusions about testing and or performance metrics, and their efforts
to test this feature/function
