Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Adding verticies on polyline between points
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Adding verticies on polyline between points (Read 2051 times)
nobody
Swamp Rat
.net stuff
on:
March 27, 2016, 09:05:20 PM »
Anyone have something already? Or know a way in autocad that will allow me to add vertices to a polyline at a specific distance between two points I select on that polyline? Hope that makes sense.
Logged
HasanCAD
Swamp Rat
Re: Adding verticies on polyline between points
Reply #1 on:
March 28, 2016, 02:46:50 AM »
I believe this is a good start
http://www.lee-mac.com/addpolyvertex.html
Logged
Sorry for my English.
Donate to Theswamp
www.sergiwa.com
ymg
Guest
Reply #2 on:
March 28, 2016, 04:10:29 AM »
Alien,
For polyline with straight segment only, I have this:
Code - Auto/Visual Lisp:
[Select]
;; addvtx by ymg ;
;; Will add a vertex to an existing polyline ;
;; Arguments: ;
;; en - Ename of a polyline (open or close) ;
;; p - Point to be added to polyline ;
;; Notes: For polyline with straight segment only! ;
defun
addvtx
en p
near par obj
setq
obj
vlax
ename
vla-object
en
near
vlax-curve-getclosestpointto
en p
par
if
zerop
setq
par
vlax-curve-getparamatpoint
en near
0
1+
fix
par
vlax-invoke
obj 'Addvertex par
list
car
p
cadr
p
For a more thorough one there is Gilles Chanteau's here:
http://gile.pagesperso-orange.fr/LISP.html
Look for
AddtVtx&DelVtx
Logged
ribarm
Gator
Marko Ribar, architect
WWW
Reply #3 on:
March 28, 2016, 08:49:31 AM »
PLINETOOLS ?
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
Global Moderator
Seagull
Reply #4 on:
March 28, 2016, 09:14:30 AM »
---------- Remove a LWpolyline Vertex --------
http://www.theswamp.org/index.php?topic=19865.0
http://www.theswamp.org/index.php?topic=5251.0
http://www.theswamp.org/index.php?topic=10344
------------ Pline Remove/ Add Bulge ---------------
http://www.theswamp.org/index.php?topic=34134.0
Remove Tim Willey
http://forums.augi.com/showthread.php?t=47762
Add Arc Elpanov
http://cadtutor.net/forum/showpost.php?p=281581&postcount=20
Add Arc Gile
------------ Pline Minimum Distance ---------------
https://www.theswamp.org/index.php?topic=50829.msg559520#msg559520
http://www.theswamp.org/index.php?topic=23170.msg279484#msg279484
http://www.theswamp.org/index.php?topic=34229.0
------------ Pline Offset Segment ---------------
http://www.theswamp.org/index.php?topic=21933.msg266096#msg266096
----------- Add a LWpolyline Vertex ------------
http://www.theswamp.org/index.php?topic=18720.0
http://www.theswamp.org/index.php?topic=30170
----------- Polyline Reverse -------------------
http://www.theswamp.org/index.php?topic=12618.msg155016#msg155016
gile
http://www.theswamp.org/Themes/oxygen11final/images/post/xx.gif
Evgeniy
http://www.theswamp.org/index.php?topic=32603.0
alanjt
http://www.theswamp.org/index.php?topic=1116.msg14511#msg14511
CAB 2004
http://www.theswamp.org/index.php?topic=12618.msg198982#msg198982
http://www.theswamp.org/index.php?topic=1116.msg14514#msg14514
----------- Ellipse 2 Pline -----------------
http://www.theswamp.org/index.php?topic=30892.msg450737#msg450737
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
